change to posi
Discussion in 'Transmission & Driveline Topics' started by runnin350, Dec 8, 2004.
  1. runnin350
    runnin350 Veteran Member
    602
    Nov 24, 2002
    Cedar City, UT
    So how easy(or hard) is it really to change out a unit and put a posi in? I have heard really difficult and piece of cake. Whats the deal?
  2. big gear head
    big gear head Veteran Member
    5,864
    15
    Jul 30, 2001
    Central City, Ky.
    This is for the 8.5 10 bolt. Remove the cross shaft retaining bolt, cross shaft and c clips and remove the axles. Before you remove anything else from inside the housing you must use a dial indicator to check the backlash on the ring gear. If you don't know what the backlash is then you will not know what to set it to when you install the posi. To check the backlash you must wrap something around the yoke and housing to hold the pinion perfectly still. If it moves ANY you will get an inaccurate reading. Set the indicator up so that it measures rotation of the ring gear. What you will be measuring is the space between the ring gear teeth and the pinion teeth. This is the backlash. This should be around .008 to .012 inch if the gears are pretty good. Now that you know what the backlash is you can mark the right bearing cap and remove the caps. Do not mark the left cap with a punch or chisel. This will cause a weak place in the cap and it could cause it to break. There is no need to mark both caps, and the left cap carries more load than the right cap, so only mark the right cap. You must mark the cap so that you know how they came off and you can put them back exactly the way they were. Now pull the differential out of the housing. There is no reason to mark the bearing races and shims because you shouldn't be using them again anyway. Remove the ring gear from the differential and install it on the new posi. Remember that these bolts have left hand threads. Torque the ring gear bolts to 65 foot pounds and use some Lock Tight on the threads. You should have new Timken bearings installed on the posi. Be sure that the bearings are seated completely against the case. You will need a good shim set to get the backlash set correctly. Install the posi with the bearing races and slip about .225 shim into the left side. Be sure that this doesn't jam the ring gear into the pinion. Now start adding shim to the right side until it is tight. When you get the shims tight install the bearing caps and check the backlash. There is no need to torque the cap bolts at this time, just get them snug. Make adjustments to the shims until the backlash is correct. When you have the backlash correct then you should add about .003 to each side until the shims are very tight and the differential can not be pulled out by hand. Check the backlash again to be sure it didn't change. Now torque the cap bolts to 60 foot pounds and finish assembling the rear end. If you use a 80W90 mineral based oil you will need to use a bottle of GM additive 1052358 in the oil.
    Byars Performance LLC
    High Performance Drive Train Parts And Service
    www.lubedealer.com/biggearhead
  3. runnin350
    602
    Nov 24, 2002
    Cedar City, UT
    So as long as I take my time and check everything over it shouldn't be too bad, right?
  4. phillyparot
    phillyparot Member
    92
    Nov 30, 2004
    Philadelphia, MS, USA
    Great explanation, Big Gear Head!
    I thought this was supposed to be fun?!
  5. El Guapo
    El Guapo Veteran Member
    1,531
    Feb 18, 2004
    Greensboro, NC USA
    BGH certainly knows his shizznit!
  6. Mountaineer
    Mountaineer Veteran Member
    Why not just install a Powertrax?
  7. classicz28
    classicz28 Veteran Member
    710
    Feb 4, 2002
    longwood, fl, usa
    You should right a book..... You really know how to explain things without being too techical... Thanks for the great info..
  8. jeff81
    jeff81 Veteran Member Lifetime Gold Member
    630
    Jul 7, 2002
    Thomson, IL USA
    BGH is the MAN. One thing you might consider, is a LOCKRIGHT setup. If you have an "open" differential, then for about $200 you could install one of these in your existing diff, and WHALLAHH!! POSI!! Did this myself, and it was pretty straight-forward.
  9. runnin350
    602
    Nov 24, 2002
    Cedar City, UT
    Hmm.. this lockright sounds interesting. No problems? And it wasn't too hard? I'll look into that...Oh, and I found out the rear end is from a 75 Nova. Surprised me just a tad!
  10. runnin350
    602
    Nov 24, 2002
    Cedar City, UT
    Auburn makes a product similar the that and its cheaper. Do you get what you pay for in this sense or is it ok?
