charging battery at track
Discussion in 'Competition Camaros' started by cutty, Aug 2, 2014.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    just wondering on what you guys are using for a quick charger at the track,and what kind of times it takes to charge it,
  2. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    I have always run an Alternator.
    I see many have generators from HF to an Onan etc.
  3. bracketracer-78
    bracketracer-78 Veteran Member
    730
    61
    Sep 5, 2003
    Stevens, PA USA
    +1, I get a lot of grief running a alternator but I do not have to charge the car between rounds.
  4. Mike N
    2,793
    557
    Jan 13, 2002
    Spencerport, NY.
    I also run an alternator but I do carry a battery charger and a generator just in case. It's a simple 2250 watt Coleman generator and a full size battery charger, on the 50 amp setting it can charge a battery pretty quickly.
  5. cutty
    342
    Dec 12, 2008
    ontario canada
    Id like to run a alternator. Just dont have to room. Am running a electric water pump
  6. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    I did too. A Moroso electric pump. I got creative with stock parts.
    I used the stock 71 spacer from the ALT to the pass head. and a 67 style top adjuster to the ALT from the empty bolt hole on the top of a long WP.
    The belt ran under the elec wp gilmer pulley
  7. Mike N
    2,793
    557
    Jan 13, 2002
    Spencerport, NY.
    I also run an electric water pump but I got creative and made my own alternator mount.
  8. cutty
    342
    Dec 12, 2008
    ontario canada
    Motor is in my mod/top truck. Wanted to finish the season before pulling motor for my z'd.tried eveything today to get 1 in there. Just not enough room in it.
  9. looker_57
    looker_57 Veteran Member
    135
    Jun 18, 2006
    minn
    alternator I did am now very happy
