Cheapest way to lower the front end ?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Docs Motorcycle Shoppe, Jan 5, 2018.
  1. Docs Motorcycle Shoppe
    Docs Motorcycle Shoppe New Member
    Dec 16, 2017
    Mt. Ulla
    So I bought a 77 LT but the front sets way to high.. Does anyone have a cheap and easy way to drop the front about 3-4 inches ?
  2. RC79camaro
    RC79camaro Veteran Member
    332
    Sep 11, 2007
    Greenville, SC
    If you really really want the cheapest...cut a coil off the springs
    Do I personally recommend it? Absolutely not
  3. Twisted_Metal
    26,960
    936
    Removing one full coil will drop it about 2".
    This does increase the spring rate a bit... By an inverse proportion of the number of coils.
    (If you had 10 coils and cut off 1... you would have 10/9ths of the original spring rate.)
    Post pics to show us how it sits.
    Unless it has no engine... I can't see why it would be sitting so high as to need a 3-4" drop.
  4. CorkyE
    10,281
    431
    The absolute cheapest and quickest way is to put blocks under the front frame/sub-frame, just slightly higher that you want it to sit, then heat the springs with a torch. No removal required, and has many side effects such as burning off the old grease around the ball joints, making a smoke show for the neighbors, and giving the volunteer fire department some much needed practice. I know a kid that did the heat treatment on a nice looking 66 Fairlane, no fire involved but in about 2 months, it was sitting on the bump stops.
    Morale of the story here - do it right with the correct lowering springs. I've done the cut and check, cut and check, and didn't like the outcome. YMMV
  5. harbone66
    3,499
    286
    Feb 15, 2011
    Central Illinois
    Buy new lowering springs but like terry said, how can it be that high?
  6. Jon Randolph
    Jon Randolph Member
    76
    May 22, 2017
    Barrington, IL
    Solid body mounts set at 1/2" body drop setting....about $100 for a 1/2" drop up front.
    Herb Adams mod out back...FREE 1/2" drop out back if you have a drill bit and some time.
  7. Desert_Dick72SS
    Desert_Dick72SS Veteran Member
    197
    Feb 10, 2009
    San Francisco Bay Area
    Nothing wrong with cutting springs...if it's done right. Just cut a little at a time and check it....
    (Certainly better than heating and collapsing a coil-old school, but I've done both in my youth...)
    -Rich
  8. 79supergasdriver
    79supergasdriver A Scholar and a Gentleman
    768
    Jun 22, 2005
    Wichita, KS, USA
    I cut coils on my previous '79 and hated the result. Yeah it sat down a bit but the springs never went back in the same and I was very careful to cut exactly one full coil so the two ends were in the same clock positions. The passenger side rubbed inside the frame and every little bump sounded just like a rusty mattress one would hear as the camera pans away from the bedroom to imply sex is happening. Decent lowering springs are not terribly expensive and available through every major retailer and someone in your area probably has a used set for sale. I got 2" drop Hotchkis sport springs from a guy for $100...then ended up buying his '79Z about a month later and putting them right back in the same car he pulled them out of lol. 26221174_1983306255018371_5219857219209969695_o.jpg
  9. tom3
    tom3 Veteran Member
    11,923
    327
    Aug 1, 1999
    ohio
    Clamps with high strength bolts and double nuts, pull one or two coils down as needed. Or add a leaf to the rear springs to level it up?
  10. John Wright
    14,666
    203
    Aug 9, 2002
    Rustburg, Va
    Cutting a coil off the front spring will work, but you will probably not have enough spring rate to hold the car up off the tires when encountering bumps in the road. I ran my car that way for awhile, but it was way better once I purchased a set of MOOG#5664 coil springs off of ebay for $54 for the set shipped to my door. These sit my car alot lower, yet have a #707 spring rate to keep the car off the tires. It sits low enough that I have to pick up on the fender to get the floor jack under the front crossmember.
    edit: added pic
    Brett Liukkonen and Rene Melten like this.
