Cloudy clear
Discussion in 'Body Restoration' started by brooksman9, Nov 2, 2019.
  1. brooksman9
    brooksman9 Veteran Member
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
    So what did I do wrong and how do I fix it? 15727171545225552434426253980953.jpg
  2. dave@ztech
    3,482
    715
    Mar 27, 2016
    NY
    What are we looking at? Was that just after a spray and dry , or after sanding?
  3. COPO
    17,930
    783
    I would use a better wax. Too bad some don’t fully explain the problems here. Where’s Sherlock ️‍♀️.
  4. brooksman9
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
    That is after a cut and buff. I was afraid to get too aggressive and only cut with 2000. I'm sure I should have started with at least 1500. Buffed with a new wool pad and some medium cut then an orange pad with some McGuires polish. My black pad came apart on me so I need to get a new one. Will this polish out with it or do I need to start over with the cutting. I used Summit acrylic enamel bright blue metallic with three coats of clear on top of that. I was concerned about the metallic in the paint is why I didn't get so aggressive with the cut.
  5. COPO
    17,930
    783
    The metallic in the paint is under the clear and is safe. Today’s clears need to be cut 2-3 days after it’s sprayed. IMO you need to cut with 1000 and work up to 2500-3000 grit. Then power buff with compound followed by power polishing with a glaze.
    Cut with wet soaked paper. Wash panels well before each grit.
    jthomas and brooksman9 like this.
  6. brooksman9
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
    Any ideas about what is in the pics? Should I start over with 1500 and go up from there?
  7. bodymanbill
    bodymanbill Veteran Member
    1,312
    680
    Feb 1, 2007
    South Park Pa
    I would remove the spoiler get some 1000 grit and sand it smooth as glass then work your way up to 3000 than buff. What compound are u using?
  8. COPO
    17,930
    783
    Looks like 1 grit paper was used which wasn’t smooth enough to buff. So your polish is stuck in the not so smooth sanding paper grits.
  9. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    Don’t use wool pads. I cannot be sure what you have was caused by the wool pad alone, but wool can burn the clear quickly. The pictures suggest that may be the issue. If that was the cause, simply resand and rebuff.
    Use only foam pads. 3M foam pads are excellent.
    I start with 1000 grit wet to level. Then 1500 wet, then 2000 wet, then I switch to 3000 grit trizact pads wet using a DA Sander, then 5000 grit trizact pads. Then buff with 3M #2 Perfect it buffing compound and #2 foam pad followed by 3M #3 polishing compound and #3 foam pad. Polish at speeds of 1200 rpms or thereabouts.
    brooksman9 likes this.
  10. brooksman9
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
    It was some Mcguires stuff I already had. I will start from scratch so to speak. Thanks for y'alls help.
