Cloudy clear
Discussion in 'Body Restoration' started by brooksman9, Nov 2, 2019.
  1. brooksman9
    brooksman9 Veteran Member
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
    Foam pads it is
  2. jthomas
    1,553
    81
    Dec 5, 2007
    NorthCentral PA
    By the way, it takes a lot of sanding with 1000 grit to cut through three wet coats of clear. Don’t be afraid to start with 1000 but watch edges. They cut quick. Just sand enough to get it flat. To check, stop sanding, wipe dry and look to see if all gloss is gone. Once you reach that point stop. Switch to 1500 and sand just enough to remove 1000 scratches, then to 2000 doing the same and so forth.
    And Copo is right. ALWAYS rinse well between grit changes.
    brooksman9 likes this.
  3. 80sz
    80sz Veteran Member
    3,199
    425
    Feb 2, 2014
    Buffalo,n.y.
  4. brooksman9
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
    Getting somewhere now
    xten likes this.
  5. brooksman9
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
    1000, 1500, 2000, 3000 and started with an orange foam pad Waiting on a blue and black pad I ordered.
  6. brooksman9
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
  7. brooksman9
    6,109
    194
    Jun 10, 2007
    Olive Branch, MS
