Cold air intake
Discussion in 'High Tech Retrofits' started by DBS, Dec 1, 2018.
  1. DBS
    DBS Veteran Member
    367
    14
    Sep 24, 2014
    Belzoni MS
    What are y'all running for cold air intake on 6.0 swap? Can I get some pics please?
  2. ULTM8Z
    ULTM8Z Veteran Member
    9,120
    334
    May 19, 2000
    Los Angeles
    whatever you do, you need to get the air filter and/or the air pickup out of the engine compartment. I did a TON of experimentation and data collection to arrive at that conclusion.
    that's really the only way you're really going to actually get "cold air".
    I dont have a LS (rather a Gen 1 style EFI system) but the principle is the same.
  3. mrfleet12
    mrfleet12 Veteran Member
    262
    64
    Aug 8, 2014
    West of Chicago IL
    Right now I'm just running an air filter off the front of the TB on my 6.0, planning to spend some time this winter looking into pulling cold air from cowl hood or from in front of the radiator support... There are some pics on the web of guys using the cowl hood on Chevelles with their LS setups..
  4. Goat
    1,905
    43
    Jun 7, 2001
    moncure, NC
    A couple of pictures of what I did...
    mrfleet12 likes this.
  5. ULTM8Z
    9,120
    334
    May 19, 2000
    Los Angeles
    very similar to mine except I relocated the battery to the trunk and then went to the passenger side.
    it's very effective. when I monitor the run data, I'm never over 10-15 deg over ambient even when in traffic on a hot day with the a/c on.
    whe driving at speed it's right at ambient temp.
    the other thing is (and I dont know about the LS engines) I had to retune the ECM to take full advantage of it... and it did make a huge difference.
  6. CAMeeks
    CAMeeks Veteran Member
    691
    34
    Jan 5, 2014
    Deer Park, TX
  7. 1971CamaroGuy
    3,763
    161
    Oct 31, 2004
    I have the spectre kit on my 71, I put it on my Christmas list last year and got it :)
    I really like it, even better than the pieces I have put together a little cheaper in the past. This kit is pretty nice.
    2017-12-25 07.23.17.jpg 2018-06-30 14.54.10.jpg 2018-06-30 15.02.13.jpg 2018-06-30 15.04.24.jpg 2018-06-30 15.13.26.jpg 2018-06-30 15.51.39.jpg 2018-06-30 15.51.47.jpg 2018-06-30 16.25.52.jpg 2018-06-30 16.38.47.jpg
  8. 70Chev
    70Chev Veteran Member
    244
    45
    Oct 21, 2012
    Brisbane, Australia
    Whilst mine's not an LS application, I also used a Spectre CAI kit and I love it. Don't know whether it does anything for performance, but it met a need I had for a low profile air filter and I wanted something that was just different.
  9. reedld
    reedld Veteran Member
    268
    Aug 9, 2007
    Painted Post NY
  10. badazz81z28
    16,571
    433
    Las Vegas, NV
    I wonder if they merged or got bought out...
    I also have the spectre kit. I like it.
