Compact truck ?
Discussion in 'The BS Topic' started by Led Zep, May 4, 2014.
  1. Led Zep
    Led Zep Veteran Member
    543
    11
    Mar 13, 2008
    Ky
    My mom is wanting to buy a used small truck.Looking at all brands except Dodge.Something around 10 years old,nothing older than a 2000,and with around 100K on the odometer.Budget would be anything under 7K.Only requirements, 2WD,auto,and AC.This is a second car,not a primary driver.
    What to avoid?Did any of the Ford Rangers have spark plug issues(breaking off in head,etc.)This is not a bash,just what to avoid on most models of any make.Thanks.
  2. 496z28
    496z28 Veteran Member Lifetime Gold Member
    965
    8
    Sep 23, 2007
    Oklahoma City
    Colorado is a good truck, so is the Ranger.. Ive had both..
  3. onelapduster
    onelapduster Veteran Member
    720
    May 5, 2010
    South Joursey
    I don't think the Rangers had the spark plug issue. That was with the 5.4 Triton engines having plugs break off in the head due to minimal head threads.
    I would look for a little Mazda B series truck, Toyota Tacoma or Nissan Frontier.
  4. RS1979
    3,700
    705
    Jun 18, 2013
    Memphis, TN
    The Ranger or the Tacoma are a good pick. Ford used Mazda engines in the Ranger. I didn't have any trouble out of mine.
  5. 57Plymouth
    57Plymouth Veteran Member
    1,078
    Jul 31, 2001
    Blythewood, SC
    Why not an S-10?
  6. Chevrolaine
    Chevrolaine Veteran Member Gold Member
    3,369
    194
    Aug 5, 2007
    Various barns in N. IL looking for chit.
    Agreed. See far more of them still on the road than the others mentioned.
    Some great deals on em out there also.
  7. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Agreed.
    Best in class will be the Tacoma, and they hold their value.
  8. BMR Suspension
    BMR Suspension Veteran Member
    245
    Jun 7, 2013
    Tampa FL
    The Plug Problem is with 5.4 Tritons. The Early 2 Valve Version 1998 didn't have enough Thread and blow the Plugs out of the Head. This was corrected by the middle of 99. The 3 Valve Version of the 5.4 Triton (2002 or 3) has the Plug Breaking problem - The Plug goes down into the Head about an inch. There is gap that fills with Carbon and when you try to remove the Plugs, they can and very often break, resulting in a $1500-$2000 Spark Plug Job.
    For a Small Truck I would go Toyota Tacoma
  9. tom3
    tom3 Veteran Member
    11,862
    317
    Aug 1, 1999
    ohio
    Any of the three popular small trucks would be fine. These trucks have/had been around long enough to have the bugs worked out, except maybe the early Colorado/Canyon. But the main factor is previous ownership. Finding one that has been cared for and not ready to rust apart is the thing.
  10. 91chevywt
    91chevywt Veteran Member
    206
    May 27, 2008
    South Jersey, NJ
    Ranger owner checking in. Own a 2006 2wd, 2.3 4cyl, reg cab, short bed, auto trans, and A/C. Base model otherwise. Love the truck, had it since new, won't be getting rid of it. No spark plug issues, changed them twice at 40k mile intervals, has approx 93k miles on it now and the truck is still in like-new condition except for some rock chips. Feel free to ask me any questions if you are interested in something like what I have. I'm a big fan of the Ranger personally, but respect all other small trucks around.
    Depending on what you need out of your truck, you will find that the SUV counterpart can be bought significantly cheaper than the pickup version. S10 blazer is cheaper than the pickup, 1st and 2nd gen explorers are cheaper than rangers, etc and you can get more options if you are interested in that type of thing. Plus they haven't been used as a truck. The trucks maintain more value, though.
