complete front end kit?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Jimmac, Apr 17, 2019.
  1. Jimmac
    Jimmac Veteran Member
    395
    71
    Dec 24, 2013
    tucson az
    went big block in my 71, the front emd was rebuilt back in 1980. since I'm needing new springs, may as well rebuild the front end all at once. does anyone sell a complete stock type rebuild kit? thanks. jim
  2. 79T/Aman
    2,550
    180
    Oct 7, 2004
    Dickson TN.
    I can help you with that, but the only thing I have are the later style inner and outer tie rods, so it will not look exactly the same but there is no difference in function and it will save you a boat load, the early tie rods are very expensive if they are even available.
  3. Jimmac
    395
    71
    Dec 24, 2013
    tucson az
    Do the outer tie rods fit the spindles? On the inner, again do I order a 71 drag link and the new inners fit it? Thanks jim
  4. 79T/Aman
    2,550
    180
    Oct 7, 2004
    Dickson TN.
    yes and yes
  5. badazz81z28
    17,133
    553
    Las Vegas, NV
