Computer problem
Discussion in 'NastyZ28 Gamers & Computer Gurus' started by BigBlock73, Jun 23, 2019.
  1. BigBlock73
    2,054
    61
    Jul 10, 2002
    Accord,New York
    I have a Lenovo G580 laptop about 6 years old.
    I keep getting a blue screen with:Critical Process Died
    I've unpluged,removed the battery,opened it a removed the backup battery,all at the same time.
    Same issue keeps repeating,saying it's repairing the problem.Start up screen comes up asking for the PIN.Put in the PIN and it does the same thing over and over.
    Is the repairable?
  2. 70Znut
    70Znut Veteran Member Lifetime Gold Member
    181
    78
    Feb 5, 2016
    Sarasota,FL
    Most likely this is not a hardware problem, Windows is probably corrupted.
    Backup your data, do a re-install of windows and will probably resolve the issue.
    Many laptops have diagnostics that can be accessed via F8, F10 or F12 just after power on.
    Often these diagnostics can allow a clean/fresh install of windows.
    You will probably have to re-install all your programs as well.
    But all this is cheaper than buying a new laptop.
    Good luck...Jeff
  3. Gary S
    22,650
    830
    You can easily test the hardware by downloading a live CD image with Linux on it. Then, boot it from the CD and if it runs, the hardware is good. Then, simply reload Windows like 70Znut stated.
    If it has a hardware problem (memory, motherboard, etc), Linux will crash too. If the hard drive is bad, Linux will run solely from the CD.
    Or, if you don't like the slow clunkiness of running from a CD, put the image on a thumb drive and boot from that. It will load and run much faster.
  4. 1972_Z-28
    1972_Z-28 Veteran Member Lifetime Gold Member
    2,701
    133
    Oct 6, 2005
    Sugar Land, Texas
    You may try running Lennovo vantage tool(I believe that is the correct name) it will update the hardware drivers.
    Like stated above back up any important data.
    https://support.lenovo.com/us/en/solutions/ht505081
    Is for Windows 10. You didn't specify you version.
    Prob Win 7. You can also download Win 10 to a flash drive or burn to dvd. If you want to go to Win 10. If you go that route do a clean install.
    GL!!!
  5. BigBlock73
    2,054
    61
    Jul 10, 2002
    Accord,New York
    I found that computer has ONE KEY RECOVERY option
    Pushed button and it reset but back to windows 8
    I had windows 10 on it before
    Can i reinstall windows 10 from online as I don't have a hard copy
  6. dave@ztech
    3,510
    719
    Mar 27, 2016
    NY
    Check windows site , I thought they gave out that one as an update , and if so it will be on windows site in the downloads section, good luck.
  7. 1972_Z-28
    2,701
    133
    Oct 6, 2005
    Sugar Land, Texas
  8. BigBlock73
    2,054
    61
    Jul 10, 2002
    Accord,New York
    Thanks
    Downloading now
    Hoping all goes well
  9. BigBlock73
    2,054
    61
    Jul 10, 2002
    Accord,New York
    Download worked
    All info lost, but it's working
    Like starting with a new computer
    Thanks
  10. budro6968
    budro6968 Veteran Member
    3,363
    557
    Apr 2, 2016
    Jax Florida
    Get an external drive to run back up on. This way next time something happens at least you can have your old stuff saved and reload it. It won't go back exactly the same but You will adapt.
