Connect and Cruise Throttle Pedal bracket for LS swap
Discussion in 'High Tech Retrofits' started by ks71z28, Jun 10, 2019.
  1. ks71z28
    ks71z28 Veteran Member NastyZ28 Sponsor NastyZ28 Sponsor Lifetime Gold Member
    2,144
    40
    Oct 10, 2004
    chico, ca, usa
    ****Just Released****70-81 Camaro GM Connect and Cruise DBW pedal bracket. This bracket will allow you to bolt the pedal from the GM engine controller kits to mount directly to your stock pedal location using the stock mounts. Call and order or go to our ebay store. https://www.ebay.com/itm/223547580301
    thumbnail_IMG_3436.jpg thumbnail_IMG_3436.jpg thumbnail_IMG_3438.jpg thumbnail_IMG_3443.jpg
    76z28 and dave@ztech like this.
  2. badazz81z28
    16,934
    503
    Las Vegas, NV
    It’s good to see these products making swaps that much more “bolt in” A+!
  3. Camaromurph
    Camaromurph Veteran Member
    100
    37
    Oct 20, 2018
    Naperville, IL
    Sweeeeet. I’m pretty sure my LT4 kit uses the same pedal. I’ll check when I get home tomorrow.
    Does it come bare metal or black finish?
  4. Bobby G
    Bobby G Veteran Member
    121
    Jan 2, 2010
    Rochester, N.Y.
    How about the corvette pedal. anything for that sir?
  5. ks71z28
    2,144
    40
    Oct 10, 2004
    chico, ca, usa
    let me know, I have no idea what interchange they used. I believe GM connect and cruise is using a CTS-V or a G8 pedal, can't confirm it, I would like to get the actuall part #'s or applications.
  6. ks71z28
    2,144
    40
    Oct 10, 2004
    chico, ca, usa
    I don't think its the same. We produced this one because we did a few connect and cruise swaps in the shop.
  7. ChrisK
    ChrisK Member
    39
    Jul 9, 2008
    Northbrook, Illinois
    I'm looking for a bracket for a LY6 Truck Pedal.
  8. Camaromurph
    100
    37
    Oct 20, 2018
    Naperville, IL
    Do you have a picture of the pedal? I might be able to tell if it will work. The other option is you are not too far and I have this bracket. You could see how it fits before purchasing.
  9. ChrisK
    ChrisK Member
    39
    Jul 9, 2008
    IMG_20191201_132151.jpg IMG_20191201_132139.jpg IMG_20191201_132126.jpg IMG_20191201_132110.jpg
  10. Camaromurph
    100
    37
    Oct 20, 2018
    Naperville, IL
    Well, It doesn't look like it would be a direct bolt on at all. I'm not sure just by the pictures if you could modify it to work. Looks like the LY6 pedal has a large offset to the right. I think you would need to find a way to mount it to the opposite side of the bracket pictured above to get the pedal in the right place. It's hard to tell in your photos where the mounting is on that pedal. Looks like I see a mounting hole that would go to the firewall on the first picture. If there is a second hole to the right of it you may be able to use some standoffs between that stock pedal mounting and the firewall to space it off the firewall a little bit. You are certainly welcome to come by and see the bracket, spitball some mounting ideas and such. My car is apart on the interior, no carpet, dash and such. Makes it easy to see the firewall and pedal mounting if you think that might help you visualize how to make a custom mount.
