Cool Camaro for sale
Discussion in 'The BS Topic' started by dcozzi, Jan 20, 2020.
  1. berg2695
    berg2695 Veteran Member
    298
    59
    Nov 13, 2011
    AUBURN, WA
    That fuel feed set-up looks like a burn-down waiting to happen. No real slack to allow for engine movement. Broken engine mount = big fire!
  2. G72Zed
    G72Zed Veteran Member
    1,369
    390
    Sep 8, 2015
    And I bet those needle bearings are not ageing well either...
  3. G72Zed
    1,369
    390
    Sep 8, 2015
    Yep, the hood was an after thought on that build. Commentator said it was a 4" cowl, more like 2.5" max. Bet the AFR's are all over the map with no clearance for the vent tubes, can you say "fuel wash"
  4. G72Zed
    1,369
    390
    Sep 8, 2015
    I have tested those "K&N extreme" tops, actually flows OK, 890CFM @ 20.4 H2O, but they mess things up most times, depends on the height, and there is no height to speak of in this case.
    Looks to be a solid mount on the engine side at least, most likely a urethane mount on the cradle part, your right, not good.
  5. badazz81z28
    17,434
    612
    Alabama
    This car appears to have a nice looking paint and body. The interior is "eh" and the engine bay is "eh". Not a fan of the side-pipes....I wouldn't say this is a car I would entertain unless I was going to change a lot up.
    Cheap all cracked up factory seats "eh"
    Shizzle likes this.
  6. dcozzi
    dcozzi Veteran Member
    3,277
    526
    May 1, 2002
    Phoenix, AZ
    But it has 640 horsepower an overdrive manual transmission, side pipes an old-school caltracs. That just screams party.
    But wait, there's no way it has that much power. It doesn't have an LS motor in it! :D
    And it's a bitchin Camaro.
  7. badazz81z28
    17,434
    612
    Alabama
  8. dcozzi
    3,277
    526
    May 1, 2002
    Phoenix, AZ
    You might like this car. LS7 and local to me. This car really gets with the program and eats Corvettes, Porsches and, of course, Mustangs.
    Da-bigguy likes this.
