Cool way to sand the upper quarter panel
Discussion in 'Tips 'n' Tricks Topic' started by sparkyboy, Dec 24, 2015.
  1. sparkyboy
    sparkyboy Veteran Member
    242
    15
    Feb 4, 2015
    aurora, co
    There are lots of curves that are difficult to sand on the upper part of our quarter panels near the glass. It's pretty tight where a sanding block or two handed sander thing won't work well. Before just holding a piece of folded up sandpaper and chewing up your fingertips, wrap a piece of sandpaper around a spray can, it fits almost perfect! Bonus, the primer you will need to cover the bare metal before more sanding gets shaken nicely. Use a beer can if any of your friends hassle you for not using a power sander.
    It took me 1/2 hour to get through bondo on top of cracked factory paint and primer :)
  2. sparkyboy
    242
    15
    Feb 4, 2015
    aurora, co
  3. sparkyboy
    242
    15
    Feb 4, 2015
    aurora, co
  4. sparkyboy
    242
    15
    Feb 4, 2015
    aurora, co
  5. Twisted72
    Twisted72 Veteran Member
    289
    33
    Nov 8, 2015
    New Albany, Indiana
  6. Blu-By-U 79Z
    Blu-By-U 79Z Veteran Member Lifetime Gold Member
    5,525
    13
    Feb 11, 2009
    Kentucky
    sockets also do a good job on certain body lines
  7. RS1979
    2,698
    271
    Jun 18, 2013
    Memphis, TN
    That's pretty nifty idea.
  8. tom3
    tom3 Veteran Member
    10,725
    61
    Aug 1, 1999
    ohio
    That 60 grit paper will git er done too. Great idea there.
  9. brooksman9
    brooksman9 Veteran Member
    5,852
    66
    Jun 10, 2007
    Olive Branch, MS
    I used a swimming pool noodle in those areas.
  10. 70lt1z28
    1,420
    160
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Old upper radiator hose. Cut the straight section out. Easy to hold, can dunk it in water and no metal edges to scratch things.
    You needed a new hose anyway, so make use of the old one.
    sparkyboy likes this.
