Coolant Temp Sensor
Discussion in 'Electrical Systems' started by MMFS, Jun 29, 2019.
  1. MMFS
    MMFS New Member Gold Member
    14
    Apr 29, 2019
    Austin, TX
    I cannot for the life of me get the temp sensor not to peg out my gauge. I have tried three different sensors. Is there a trick?
  2. Gary S
    22,298
    720
    If the gauge and wiring are working correctly, the only trick is to get the right sensor and connect it. The gauge uses a different sensor than the idiot lights use so make sure you inform the parts guy of that.
    The sensor for gauges is a variable resistor. The sensor for lights is an on-off switch.
  3. MMFS
    14
    Apr 29, 2019
    Austin, TX
    Anyone using A/C Delco G1852 successfully?
  4. 73RATTYZ28
    73RATTYZ28 Veteran Member
    440
    Feb 23, 2001
    White Plains NY USA
    Contact Daniel at guagemarks. He calibrated one for me and it's dead on to my mechanical gauge.
  5. Coadster32
    1,608
    128
    Oct 2, 2013
    Milford,CT
    I had a sensor read whacko on me a few times. Check the wire going from the sensor to the gauge. Make sure it's not just laying on the intake, heads, or anything else really hot. You could get false readings on the high end.
  6. Green hornet
    Green hornet Veteran Member
    1,670
    276
    Oct 11, 2015
    North Bay, CA
    Orileys, BWD WT359 with 3/8 pipe thread for a gauge.
