correct carb linkage for 700R4 t.v. cable
Discussion in 'Transmission & Driveline Topics' started by need-for-speed, Jul 8, 2004.
  1. need-for-speed
    need-for-speed Veteran Member
    610
    Feb 7, 2003
    Conroe, TX
    I've had my t.v. cable hooked to the original detent cable spot on my Edelbrock carb and it drives pretty good but wonder if using the correct geometry might improve downshifts and delay the 3-4 upshift.
    I see California Perfomance Transmissions (Art Carr) has an adapter for the Edelbrock carb but they want $38 for this piece of metal !! Do you guys know any other sources or a good drawing so I can make one?
    thanks
    2000 Corvette hardtop black, 6 speed, Halltech Tric cold air intake w/nylon MAF ends, Corsa Touring cat back exhaust w/pro tips, Taylor wires, 1/4 mile: 12.918 @ 111.29 mph on stock EMT's 330 rwhp, 342 rwt on MTI's dyno, 3075 lbs
    79 Camaro 355 CID, Edelbrock intake, Edelbrock 600 cfm carb, Edelbrock performer 64 cc alum cyl heads, comp cams extreme energy 262 cam, erson roller rockers, hooker headers, Mallory Comp 9000, 3.42 posi, 700R4 rebuilt w/ B&M kit, 2400 stall converter w/ TCI lockup kit, energy suspension f.e. rebuild, 1-1/4 front sway bar, 5/8 rear bar
    67 Camaro, 327 w/ a 'glide , waiting on "funding"
  2. SpeedAddict02
    SpeedAddict02 Veteran Member Lifetime Gold Member
    4,530
    Dec 31, 2002
    Wallkill, N.Y.
    When I switched over to the 700r4, I was highly advised by a number of members on this board to get this right. The geometry of this hookup is very important to the operation of this transmission..
    I got the kit from www.700r4.com .. Check out the site.. And the tvmadeez article..I got their kit for my performer 750 carb.. Pricey. Yes. But it is correct. And easy to install.
    1981 Z28
    400c.i.SBC/Edelbrock 750/Performer Intake/1-5/8" headers/MSD 6A w/HEI/700R-4/3.42posi-trac/B&M QuickSilver/3rd Gen Steering Box/KYB's /28"rear tires & a real heavy foot!!
  3. need-for-speed
    610
    Feb 7, 2003
    Conroe, TX
    Yeah, I've always read the same thing. I did spend a lot of time getting mine adjusted right and it shifts good. But I think I may do the Bowtie O.D. set up. I'm gonna read through those volumes and volumes of info on their website. Thanks. How did it work for you ?
  4. wayner
    wayner Veteran Member
    Here is a link to a site that sells the correct geometry corrector for the edelbrock carb. for $27.30
    http://www.powerglide.com/parts/parts/AS3-03K.htm
    Correct geometry is very inportant, read what that site says about the correct geometry for an edelbrock carb.
    70 Camaro Z/28 with 461cu.in. BBC & OD Auto, 3.31 12 bolt posi.
  5. need-for-speed
    610
    Feb 7, 2003
    Conroe, TX
    Thanks Wayner !!! That looks a lot better. I like the info and kit on bowtie overdrive, but really, my t.v. cable and cable mounting hardware works fine...I really didn't feel like spending $119.
    I don't mind spending $27. Have you used this? Are there good instructions on the set-up? It looks like it just bolts on where the existing ball stud goes.
  6. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Yeah, I'm interested too. I just made the switchover as well a month ago. Does this thing really make a difference?? Any tranny guys in here that can vouch for it's necessity??
    Jakeshoe, Chris ??
  7. SpeedAddict02
    4,530
    Dec 31, 2002
    Wallkill, N.Y.
    I'd also like to see what they have to say about that product.. I've seen it b4.. But with the BTO kit, they give you a bracket that attaches to the carb linkage, a special cable for that linkage, and a different spring for the valve in the va;vebody that must be used also..
    I've been driving mine since March.. Took a few adjustments to get it right.. But now it shifts good in all gears.. Little soft for me, but its a stock trans.. I plan on rebuilding it and installing a trans go kit this summer.. As well as the H.D sun gear shell, better clutch packs, band, boost valves, vette servo & 10-vane pump..
    I also run it with the stock converter.. Which I know is hurting my performance.. Car is like a dog off the line compared to the way it use to be.. But with the rebuild, I will probably add a B&M Holeshot 2400..
    Anyways, I'll check back to find out about that bracket.. lol
  8. need-for-speed
    610
    Feb 7, 2003
    Conroe, TX
    Sounds like you're skeptical based on the "lol" . I understand. There's a big difference in the 2 prices and approaches. I'm going to do more research before I buy but: there is nothing special about their t.v. cable . I also don't understand why the spring in the tranny needs to be changed. As I recall, it's just a return spring. It's not like it's part of a regulator. I think I'll look in the service manual I have for the 700R4. I got my 700R4 (4L60) transmission out of a '92 Camaro w/ a 305 so it already had the extra clutch plates and 10 vane pump. I got the O.E.M. t.v. cable w/ the tranny and it works just fine. We rebuilt mine w/ the B&M rebuild kit and we added the corvette servo and the W.O.T. kit. I also used a t.c. w/ a stall about 200 rpm higher than stock and my transmission shifts nicely. With the old tires (215 70R 14) is would do a burnout at the 1-2 shift (not just a chirp) and get a 3rd gear scratch too. So it shifts good, although it shifts at a lower rpm than I would like (unless I shift manually). That's what I'm hoping to cure. So, my dilema is which solution to buy. I'll keep researching it.
    Does anyone have any pics of their new and improved bracket? Please post here or email to me at mmugnier@gt.rr.com My t.v.cable connection on the carb is already very close to the A/C compressor bracket.
  9. SpeedAddict02
    4,530
    Dec 31, 2002
    Wallkill, N.Y.
    I didnt mean the "lol" in a sarcastic way or anything like that.. But I am curious as to whether or not the other kit will perform properly..
    The cable that comes with the BTO kit isnt special per-say, but you cant use a stock-type cable with their kit.. The difference is on the end. Their cable has a ball-end, like a bicycle brake cable does. That ball goes into the bracket and allows it to pivot with the bracket as the throttle is moved..
    The spring, i dont remember exactly why. But I may double-check their site and my instructions, I can find them, to find out why you gotta change the spring.. But I do remember them saying you gotta use it.. Think it may be a tad shorter or longer..
    But if you find anything out about the other kit, please pass on the info.. I'd appreciate it.. Might wanna drop an email to one of the pro-trans shop/builders that frequent this site.. Like Chris @ CKPerformance, or Steve @ Oldani Motorsports.. I may do the same b/c its got me very curious..
    1981 Z28
  10. need-for-speed
    610
    Feb 7, 2003
    Conroe, TX
    I'm curious if the $27 bracket will do the trick as well. I will let you know what I find out.
    Hey speedadict, what is involved in replacing the steering box with a 3rd gen steering box? I'm interested in that one. Was it difficult?
    [This message has been edited by need-for-speed (edited July 11, 2004).]
