couple questions about holleys
Discussion in 'Engine Topic' started by cutty, Mar 14, 2012.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    i took my 750 vac apart to clean and rebuild, upon taking the front bowel off this thing fell out, is it needed? also my holley has had it choke milled off, i had it hooked up and strangely enough turn the key and would run, no fighting to start it or even stalling, is this ok, i know it sounds odd but every 1 ive had like this, i had to rev till it got warm, ive checked and rechecked for vac leaks and nope nothing( not complaining just think its odd)
  2. CorkyE
    10,453
    508
  3. cutty
    342
    Dec 12, 2008
    ontario canada
    plugs look good, ive been scratching my head on that 1, how does that thingy attach, its my first holley to ever have 1
  4. COPO
    18,065
    869
  5. cutty
    342
    Dec 12, 2008
    ontario canada
    thanks for the information, and nice rebuild section, i took the bowel off and it fell out,
  6. cutty
    342
    Dec 12, 2008
    ontario canada
    ok guy it rebuilt and now back on, still giving a little bit of trouble, the 1 thing i did noticed is my ported vacuum port has vacuum at idle, what could cause this? transfer slots open to much? or??
  7. COPO
    18,065
    869
    Use manifold vacuum at the base below the front fuel bowl.
  8. cutty
    342
    Dec 12, 2008
    ontario canada
    i know that,
    im trying to figure out why i have vacuum on my ported vacuum side.
  9. Jim Mac
    Jim Mac Veteran Member
    2,196
    Dec 28, 2004
    tucson az USA
    could be your throttle is open a bit too far. jim
  10. cutty
    342
    Dec 12, 2008
    ontario canada
    i set the Secondary throttle stop screw at a 1/2 turn out, should i try 1 full turn? as of right now, i cant tune it with the mixture screws, as its doing nothing right now, can turn them all the way in and does nothing,runs the same,vac gauge shows 8 inchs of vac at idle, its not jumping around( stays steady)
