Cracked Housing on TH350
Discussion in 'Transmission & Driveline Topics' started by FadedSS, Sep 8, 2010.
  1. FadedSS
    FadedSS Veteran Member
    195
    Jan 27, 2010
    San Jose, CA
    Hey guys, I was tightening down my TH350 tranny to the motor when the transmission housing cracked. Can I simply get this welded/repaired or am I dealing with a bigger issue???
  2. GetMore
    2,870
    Nov 8, 2004
    Patterson, NY
    not impossible to repair, but it may not be worth it.
  3. BondoSpecial
    8,699
    Sep 20, 2004
    Southern Maryland
    my question would be, why did it crack, there should be zero load on that ear when you are tightening it. I'm guessing you didn't have the converter seated... which means you may have damaged the pump putting that much load on it
  4. Mr Big Nasty
    Mr Big Nasty Veteran Member
    140
    Mar 22, 2010
    Georgia
  5. 5spd540
    12,283
    Sep 19, 2009
    Guyton, GA
    I had one do the same thing in my prostreet s-10
  6. FadedSS
    195
    Jan 27, 2010
    San Jose, CA
    good point...i made sure the convereter was properly seated though.
    i am going to have my buddy repair the crack tomorrow, it does look a lot worse in the pics than in person.
  7. FadedSS
    195
    Jan 27, 2010
    San Jose, CA
    did you repair it?
    thanks for the input guys, please keep it coming...
  8. 5spd540
    12,283
    Sep 19, 2009
    Guyton, GA
    Just got a new case.
  9. muscl car
    19,621
    78
    Jul 8, 2001
    san bernardino calif
  10. Cardinal
    8,175
    Jun 22, 2003
    Endicott, NY
    Only one thing that caused the bell housing to crack and that is that the converter wasn't completely seated into the pump. IF you are lucky, it didn't destroy the pump. Most likely it did and, at the minimum, you're headed to a new pump BUT most likely, are going to need a whole new transmission.
