Crank gear removal
Discussion in 'Engine Topic' started by CamaroMan79, Jan 28, 2010.
  1. CamaroMan79
    CamaroMan79 Veteran Member Lifetime Gold Member
    5,187
    Jun 10, 2001
    Selah, WA
    Whats the best way to take a crank gear off a sbc crank? I tired putting apuller on there and my puller center bolt ended up snapping off. Howabout applying some heat to it?
    btw this is in an assembled engine.
  2. Cardinal
    8,186
    Jun 22, 2003
    Endicott, NY
    Are you replacing the gear or trying to save it?
    Replacing/removing a stock link belt timing chain crank gear: put a clean lint free rag under the crank to prevent the gear from falling into the pan. Take a good chisel (1/2" or wider will do) put it between the teeth of the gear near where the keyway on the crank is. WACK the chisel with a hammer and the gear will split in half. Done.
    If it's a double roller chain timing chain crank gear, you should be able to put a split puller on it the pull it off like this one: http://www.sears.com/shc/s/p_10153_12605_00999046000P?keyword=pulley+puller
  3. hhott71
    hhott71 Veteran Member Lifetime Gold Member
    14,375
    Mar 30, 2001
    Joplin Mo. 64801
    You need a HD Vacuum cleaner.........
    OR Use a Gear Puller.
  4. COPO
    15,699
    118
    Toronto
    I used a 3 claw arm tool that comes with a centre pointed post to remove mine and it came off easy.
    A new one was going on anyways along with a cam sprocket and chain.
    It looked something like this I borrowed from my engine builder.
  5. wiseryder
    1,848
    8
    Sep 11, 2004
    belding,mi USA
    Seriously???
    I've never heard of that :eek:
  6. deputyrob
    deputyrob Veteran Member
    866
    Jun 22, 2008
    Canal Fulton Ohio
    three finger gear puller works every time..just like COPO posted. get a harbor freight speacial and ur good to go.
  7. badazz81z28
    13,724
    81
    Las Vegas, NV
    That will not work if you have a steel gear. I have seen some small blocks with what looks like a plastic gear and that procedure would probably work.
    IMHO, A little heat and the proper tool will get the job dont and not damage anything.
  8. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    "Originally Posted by Cardinal
    Seriously???
    I've never heard of that."
    Suckers are powder gears and will snap in a NYM doing this! And be careful you don't break the cast crank's snout off while doing this!!
    Now, steel gears, NO!
    Pull them off!!
    pdq67
  9. COPO
    15,699
    118
    Toronto
    ^^ and hope you don't get a nice gouge in the crank. Get the proper tool and don't be cheap about it or Murphy's Law will kick in then you'll be :whine: .
  10. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    Use a dull 1" wide cold chisel set at the side of the key-way and a 3 pound Ford tool and go.
    No problems at all and I've done in many times!
    pdq67
