Crank is shot, thoughts?
Discussion in 'Engine Topic' started by 79RedZ, Dec 29, 2019.
  1. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    I spoke without realizing that the Scat crank in question was cast and not a forged piece. I used one of their forged 4340 cranks in my current sbc....I hope it holds up okay.
  2. 1980RS
    1980RS Veteran Member
    3,563
    652
    Jun 17, 2006
    MN
    For the cost it cheaper to get a new scat crank than fix that old one.
  3. G72Zed
    G72Zed Veteran Member
    1,263
    302
    Sep 8, 2015
    I'm sure it will be fine, those 4340's forged ones take quite the abuse in Circle Track application. What are you making for HP, max RPM?
  4. John Wright
    14,712
    215
    Aug 9, 2002
    Rustburg, Va
    Hasn't been on a dyno, but expect it is around 550 at the tire and I turn it to 65-68. It doesn't nose over under boost so I have to watch the shift light pretty close and resist the urge to let her eat.
  5. Cardinal
    8,281
    33
    Jun 22, 2003
    Endicott, NY
    OUCH! IMHO, get a new crankshaft.
  6. 79RedZ
    79RedZ Veteran Member
    716
    54
    Mar 24, 2009
    Hamilton,MI
  7. 79RedZ
    716
    54
    Mar 24, 2009
    Hamilton,MI
    Yep. Looks like I can get a new one from summit for $267.
  8. vegas1974z28
    4,661
    123
    Jan 10, 2002
    Las Vegas,NV
    This sounds like the problem I've been having..... Interested to see what the problem is. We replaced the crank, even after it balanced out.
    It sheared the cam bolts off the timing chain.
