Cruise Control Tilt Steering Column
Discussion in 'High Tech Retrofits' started by kboxx, Mar 7, 2011.
  1. kboxx
    kboxx Veteran Member
    149
    Dec 12, 2010
    Bellingham, WA
    I figured since I was going through the trouble of installing an LS2, I would go ahead and swap out the steering column to add cruise control to a 70.5. It does not seem like there are many Camaro cruise control columns out there available for sale. I think others will fit, but does anyone have suggestions on alternatives?
  2. 70ZED
    70ZED Veteran Member
    223
    Jun 21, 2010
    Calgary, Alberta Canada
    You don't need to swap out the steering column to add cruise. Just pick up a complete cruise control out of any GM pickup, A, B, F body from say 1974 to 1987 and it will bolt in pretty well.
  3. tdm119
    tdm119 Veteran Member
    177
    Oct 8, 2009
    Kansas City Mo.
    I am installing a 99 camaro column in mine, still in the works. I paid $70 shipped for the column from ebay.
  4. Prototype4342
    Prototype4342 Veteran Member
    1,483
    Sep 10, 2010
    Las Cruces, NM
    they have aftermarket cruise control kits that you can buy. i don't know where though. i'm sure a google search would hep though.
  5. Fbird
    2,177
    26
    Feb 12, 2011
    atlanta, ga
    Dana corporation makes very good cruise units.....but you will definately want to order the correct "triggering" device.....ie pulse or magnet...depends on tranny...
  6. PolarBear
    1,198
    Apr 24, 2008
    NJ
    Later 3rd gen column will practically bolt right in but there are cruise bolt in stalks available as others have mentioned
  7. 71RS/SS396
    71RS/SS396 Veteran Member
    2,520
    13
    Aug 26, 2008
    Wake Forest NC
    Call Street and Performance and talk to Tony. I added cruise to my Dad's 62 Bel-Air Bubbletop w/ an LS-2 and drive by wire throttle body. We used a stalk off of a 85 or 86 ( I don't remember which year ) chevy pick-up with cruise and no intermittent wipers, a Trailblazer SS Gas pedal, and ran it through the computer and it works great. Tony should be able to give you specific part #'s. You don't need to change the column except for tilt this set-up works on any GM column.
  8. sbca96
    sbca96 Veteran Member
    2,883
    Oct 25, 2004
    Santa Barbara, Ca
    Interesting, I was curious if this was possible, I have a 1999 Camaro one and a
    1994 Firebird one at my disposal.
    Tom
  9. PolarBear
    1,198
    Apr 24, 2008
    NJ
    The late 4th gen, 99 and up, isnt as desireable as the dash bracket is welded to the column. The 3rd gen uses a bolt on dash bracket and you can swap the 2nd gen bracket to the 3rd gen. You can use the 4th gen column but you have to modify the brackets a little. Also the connectors for the tur signals and such are different between the 2nd and 3rd/4th gen
  10. BLKnBad71Z
    BLKnBad71Z Veteran Member
    1,399
    Sep 20, 2000
    Buffalo,NY,USA
    What has to be done to use the 3rd gen in a 2nd? Thanks
