Custom A/C control panel?
Discussion in 'Interior Restoration' started by ULTM8Z, Aug 26, 2018.
  1. ULTM8Z
    ULTM8Z Veteran Member
    9,132
    336
    May 19, 2000
    Los Angeles
    Anyone running one? I have a Classic Auto Air A/C system from around 2008-2009 time frame. Was curious to see about upgrading to a more modern looking setup.
    I think their systems are all computerized now, so not sure their current custom panel would be compatible with my old "mechanical" setup. I'll probably call them and see this week.
  2. ULTM8Z
    9,132
    336
    May 19, 2000
    Los Angeles
    it's just as I thought... their control panel isn't compatible with the older cable driven systems. shucks...
    maybe I'll have to come up with something on my own I guess.
    I dont have the heater hooked up and I never have to use the defrost... so should really just be fan speed and A/C on/off. I always run the AC on max no matter what car I'm in, so the mixing is unnecessary too (considering I have no heat either).
  3. ULTM8Z
    9,132
    336
    May 19, 2000
    Los Angeles
    decided to make my own... kind where i'm headed in the picture
    Figure I'll relocate the hazard as well as the interior light switch (since I never really touch my headlight switch anymore due to the auto turn on module).
    also since I don't have my heater hooked up on the CAA system, no reason to have a mixer... the system is either on or off, so may as well just use a toggle switch.
    printed the black background with a laser jet printer
  4. NeoNeuro
    NeoNeuro Veteran Member
    188
    Aug 4, 2014
    Panama City, FL
    Looks nice!
  5. ULTM8Z
    9,132
    336
    May 19, 2000
    Los Angeles
    mrfleet12 likes this.
  6. Twisted_Metal
    26,960
    936
    Nice fit! :D
    Where did you get those switches?
    Are the indicator lights on the switches functional too?
    What's in the vent housing to the left?
  7. ULTM8Z
    9,132
    336
    May 19, 2000
    Los Angeles
    The rocker switches and face plates are from Rocker Switch Pros... I heard about them through pro-touring.com...
    RockerSwitchPros.com
    Basically you can design your own face plate, get different color LED's, etc. It's really cool and they're pretty inexpensive too.
    Everything is functional, yeah. The top of the switch lights up with the headlights, and the bottom light enables when the circuit is activated. You have to get the DPDT version. The wiring isn't trivial, but it's not that bad if you have a little electrical know-how. The only bad part is that they're mostly obscured by the steering wheel when I'm driving, so I don't get to appreciate them illuminated when I'm driving at night... lol... But I like the feel of the switches and the knob compared to the prehistoric sliders on the factory panel..
    I also replaced the side vents with circular ones from Nostalgia air. I wanted to update the look and match the circular ones I"m running on the upper dash. The grain is basically some drawer liner from the local hardware store that just happened to match the madrid grain nearly identically, and with a very light mist coat of semi-flat black it fits right in. I had to do some stuff behind the plate to attach it to the dash.
