Custom Trunk
Discussion in 'Car Audio, Electronics & Security' started by jthomas, Aug 22, 2016.
  1. jthomas
    1,544
    76
    Dec 5, 2007
    NorthCentral PA
    Have thought about sprucing up my trunk audio components but didn't want to do a full custom job because I need space for folding chairs and cleaning stuff so I went with a semi-factory look:
    GM didn't use gray/white trunk spatter paint in the early second gens, but it looked best with my paint scheme. Behind the 10" sub is a sealed box with a full 1 cubic foot of space. It turned out great and the bass is a lot better than before.
  2. Coadster32
    1,624
    131
    Oct 2, 2013
    Milford,CT
    Looks great. Good lob.
  3. Twisted_Metal
    26,949
    930
    Nice Work! :cool:
  4. bodymanbill
    bodymanbill Veteran Member
    1,262
    616
    Feb 1, 2007
    South Park Pa
    Dam that looks nice, also like how you took the stripes all the way to the end of the filler panel
  5. jthomas
    1,544
    76
    Dec 5, 2007
    NorthCentral PA
    To tell you the truth I wish I hadn't done that. The correct way is to end them just below the first bend on that panel. I used the Phoenix Graphics stencils to get the stripe painted right, but they are not the best product and I had some bleed under the stencil in another spot so I decided it was easier to run them all the way down and avoid that. Thanks though.
  6. Bumpad_Z28
    Bumpad_Z28 Veteran Member
    500
    Apr 9, 2004
    Logan, UT
    Wow ! Nice :)
  7. APEowner
    APEowner Veteran Member
    646
    12
    Dec 9, 2013
    Albuquerque, NM
    I prefer them the way you did it. Also, nice job on the trunk.
  8. cvhu
    cvhu Member
    97
    Jan 18, 2012
    sarnia, ontario, canada
    here is a couple before and afters of my trunk
  9. jthomas
    1,544
    76
    Dec 5, 2007
    NorthCentral PA
    Nice job cvhu! I thought about doing all sides like you are doing, but I couldn't get all my gear in the trunk that way. I like the way your's turned out. By the way, nice blue Camaro...I'm a bit partial to blue :)
  10. cvhu
    cvhu Member
    97
    Jan 18, 2012
    thanks jthomas the blue on my car is from the 2014 corvette its called laguna blue pearl, your trunk looks awesome nice clean, i have a hidden sub box behind the main panel of the trunk
    jthomas likes this.
