cuting my coils to drop front end
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by mcmurphy2121, Mar 2, 2012.
  1. mcmurphy2121
    mcmurphy2121 New Member
    10
    Dec 27, 2011
    calgary alberta
    I want to give my 79 z28 a mosre aggressive muscle look by dropping the front end and lifting the back can anyone help me on this one I need full details thanks brothas
  2. larrylarry
    larrylarry Veteran Member
    1,553
    72
    Dec 22, 2011
    San Antonio Tx
    Depending on what you have hanging on the bottom of your Z will dictate how low you can go.I have a 78z same as yours, w/headers & pipes that Ive already scraped on the higher speed bumps and this is with a slightly saging stock suspenion.I just ordered front springs with a 1in. drop.Thats all Im going to lower it.Go to some of the post about 2 weeks ago about cutting coil springs, good info. their.Also why would you want to raise the rear end,maybe to use the front air dam as a snow plow? Lots of snow up their I hear.Sorry I just couldnt help my self, I just had to add that in.....
  3. The Champ
    The Champ Veteran Member
    4,648
    579
    Sep 14, 2000
    MN
    FWIW - A general rule of thumb is cutting 1 coil equals a 2" drop.
    But that is a "general" rule - no guarantees.
    Once you lower the front, the rear will look higher (and the back bumper will be higher).
    The rear can also be "raised" just by using taller tires.
    This is our car with 2" drop Eibach lowering coils in the front, the origial rear springs and 27" tall rear tires.
  4. Todd37604
    Todd37604 New Member
    23
    Feb 7, 2012
    Dayton, Ohio
    my header's and pipes have hit everything from the curb at the end of my drive way, to the speed bumps in the bank parking lot. Sometimes it's a pain to not be able to go certain places but hey it's the price we pay for being die hard camaro lover's!
    ps, going over a hill at top speed's tends to bottom out quite a bit when you cut coils.. lol bad experience.
  5. DMSTAINLESS
    DMSTAINLESS Veteran Member
    515
    Sep 19, 2010
    ILL
    Best bet is not the easiest, but to start with fresh springs, then remove and cut 1/4 of a loop, reinstall and chk ride height, and repeat till u get where u want. Cut with cut off wheel not a torch.
    Easy peezy
    Good luck
  6. twood
    twood Veteran Member
    330
    Feb 3, 2012
    Glen Morris, ON Canada
    Just saw this on Car Warriors... They had a early 70s Camaro.The one team cut one coil right away without doing it in stages. It was a disaster. When they did a burn out, the front end dropped down so much the front tires were doing their own burn out against the inner fenders ect...
  7. Todd80Z28
    11,554
    242
    Jun 11, 2002
    Northern VA
    I wouldn't suggest cutting old springs. The rate wasn't high enough on them to begin with.
    Pick a ride height (as measured from spindle center to fender lip), and I can probably suggest a low-cost Moog replacement spring.
  8. wayback
    wayback Veteran Member
    1,718
    Mar 5, 2000
    Jungleland, Minnesota
    ^ +1
    New springs and no cutting would be an inexpensive way to get what you want.
