cutting clear coat question
Discussion in 'Body Restoration' started by Scatter, May 29, 2015.
  1. Scatter
    Scatter Veteran Member
    2,300
    Jun 26, 2003
    Millbrook, Al
    hey guys, so I painted my car A dark grey color (bc/cc) and I am trying to cut the clear coat flat. the problem is when I'm wet sanding it's pretty hard to see when I have it completely flat. I have to stop and dry the area wait for the water to evaporate and then I can see the dimples I have left. as you can imagine it's taking a long time to get it done. what I'm wondering is, is there anything I can use to help highlight the low spots? I tried spraying some sandable primer, but that just gums up the sandpaper fast. Y'all have any recommendations?
  2. Mike Bozung
    Mike Bozung Veteran Member
    144
    Jul 7, 2011
    muncy,pa
    Please don't spray any primer from now on. All you need is a 2" X 4" rubber squeegee ( on line at "Auto Body toolmart) It will take that water film right off for you. The most important thing with wet sanding is to use CLEAN water though out the whole process. I use a spray bottle with clean water and spray it on the area I'm sanding constantly. I also have a bucket of clean water that I have a clean terry cloth rag in to wipe off the sludge. You'll also need a soft sanding block ( about 2" X 6" ) to wrap the sand paper in. Try to sand in a criss cross motion rather then straight back & forth. I can tell you one thing. To do it right will take LOTS of time. Don't stop until it's right.
    Good luck.
    Mike
  3. kustom77
    kustom77 Veteran Member
    147
    Feb 10, 2002
    Morriston Florida usa
    There is no special product that I'm aware of.. Cutting clear is a slow time consuming process. The above poster has great advise that I will second.
  4. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    ^^^spot on.
  5. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    To dry faster I use a small squeegee or a somewhat soft rubber block and loads of white paper towels. There really are no shortcuts to this process. As mentioned super important to keep surface flooded with water. Paper will cut better, not abrade the paint and last longer.
  6. Scatter
    2,300
    Jun 26, 2003
    Millbrook, Al
    I appreciate the advice, & I basically have the same set up with a bucket and a bottle of clean water. I even use a squeegee, but it might be just worn out its not removing enough water......that's gotta be it.
    Off to grab a couple new ones....thanks!
  7. Scott_H
    Scott_H Veteran Member
    365
    Feb 10, 2003
    Pasco, WA, USA
  8. 76_TypeLT
    6,389
    144
    Jul 26, 2008
    Houston, TX
    When I was doing my first run at sanding I would take my sweet time and squegee off fairly frequently to see what my progress was. I'd rather take more time so I can remove as little clear as possible. Once the peel, trash, etc is removed then I know I can stop and move on to the next grits.
  9. earlysecond
    earlysecond Veteran Member
    5,618
    Aug 9, 2002
    Altoona, PA
    The sanding block that you are using, hopefully, is all the squeegee you should ever need. Swipe it back and forth and dry with a chamois. You still have to wait OR you can blow it dry with air if you want. I suppose you could sand until you believe it is good enough knowing that there may be a spot or two you will have to come back and hit again. Wet sanding is laborious and takes a lot of time.
  10. mark wagner
    mark wagner Veteran Member
    2,129
    18
    Jul 31, 1999
    Saylorsburg Pa. USA
    add a couple drops of soap (dish soap works fine) to your sanding water-it helps keep the sandpaper from loading up , making the sanding process easier
