cutting gas tanks
Discussion in 'High Tech Retrofits' started by BC's71', Mar 6, 2006.
  1. OldSchoolFormula
    OldSchoolFormula Veteran Member
    119
    May 26, 2004
    Livermore
    My buddy started cutting his tank while it was still full of water using air tools. Once it was open it was a lot easier to air out.
  2. patgizz
    patgizz Moderator Lifetime Gold Member
    12,737
    Apr 10, 1999
    Cleveland
    advance auto has them for $182 with filler neck(or $184 without LOL)
  3. CanadaGreg
    CanadaGreg Veteran Member
    714
    Sep 10, 2002
    Kitchener, Ontario, Canada
    I've gotten quotes around 220-230 for a new tank up here from the auto parts places (parts source, napa). That's canadian, but it's in line with what you guys are paying.
    Since no one has voiced it yet, I'm looking very seriously at a surge tank setup for my EFI conversion (on my current engine). Bascially you just install a 1 liter reserve tank at the front of the car with the pump in there. Now, I'm not sure how useful that is to you LSx guys, since you won't have a mechanical pump anymore. But for the conversion guys like me it doesn't look too bad. The mechanical pump fills the surge tank (with return line to tank) and then you have a high pressure circuit from there on like a normal system. I haven't decided for sure yet. But for the extra fabricating there I won't have to touch my stock tank and for my situation, it actually makes things a bit simpler.
    http://www.sdsefi.com/techsurge.htm
  4. BC's71'
    BC's71' Veteran Member
    1,125
    May 16, 2000
    North Chicago Suburbs
    That's pretty neat, actually! Wonder how the noise issue is witha pump running in there....
    The noise thing is what's stopping me from adding an external fuel pump and leaving stock tank/pickup alone. Plus, in-tank pumps generally run cooler and therefore have a longer lifespan (from what I've heard).
  5. Rick WI
    Rick WI Veteran Member
    10,400
    Jul 9, 2001
    Madison, WI
    You can get a VERY quiet Bosch fuel pump through Accel that can either be mounted internal or external. It will flow enough to support 850 HP @ 45 PSI and is what I run. It's an excellent pump. It's what the Indy cars run.
  6. DirtyScotty
    DirtyScotty Veteran Member
    814
    Jan 27, 2004
    Caledonia. Ont. Communist Canada
    Has anybody heard of this? Put a hose from the tailpipe of your car and put the other end of the hose into the sending unit hole and start the car. The exhaust apparently neutralizes the gas fumes. Sending the fumes out of the filler neck. This person said that you can cut and weld all you want. Ever heard of this? My friend who is stoned right now just told me this. No kidding. So I'm posting!:screwup:
  7. gregh
    gregh Moderator Staff Member Lifetime Gold Member
    4,173
    Jun 24, 2003
    Calgary, Alberta, Canada
    I think your buddy has been sniffing to many exhaust pipes or some other kind of pipe.
    The carbon monoxide & other vapors in the exhaust will displace the normal air in the tank so the risk of a gasoline vapor explosion is slightly reduced. But it's still a very foolish thing to weld on any enclosed container that once held explosive liquid unless you are a very well equipped shop & have done all the proper cleaning & venting procedures.
  8. schitzo
    schitzo Veteran Member
    1,300
    Feb 12, 2005
    Minneapolis MN
    I am in the 'chicken out' group....bought a new tank from eBay and got it welded to suit my needs
