cylinder wall scratches
Discussion in 'Engine Topic' started by jpe, Aug 24, 2014.
  1. jpe
    jpe Member
    32
    Dec 2, 2012
    Finland
    What do you say about these scratches found in couple of cyliders? Good to bolt heads and go or should i lift the motor and rebuild it? I can feel the scratches with my finger nail, but the nail does not stop to them. Motor eats some oil, but not much at all, i think that valve quide seals are bad and that's why it eats some.
    Before cleaning pistons, so it burns some oil.
  2. Damon
    Damon Veteran Member
    12,939
    21
    Nov 16, 2000
    Philly area
    If it's a "just get it running again" type operation, then go ahead and button it up. Anything more than that, I'd pull the motor and at least have the cylinders honed out again. A couple of those vertical scratches are fairly normal on just about any street motor, but you've got a lot more than a couple.
  3. hhott71
    14,377
    Mar 30, 2001
    Joplin Mo. 64801
    Normal.
    Run it as is.
  4. CNC BLOCKS
    CNC BLOCKS Veteran Member
    1,643
    8
    Oct 11, 2004
    NORTHEAST
    Interesting I don't see cylinders scored like that with my engines,
  5. Bikefixr
    Bikefixr Veteran Member Lifetime Gold Member
    1,761
    46
    Mar 13, 2006
    Run some 400 grit over it and button it up.
  6. Damon
    12,939
    21
    Nov 16, 2000
    Philly area
    Obviously, you care too much about your work and don't drop the recommended handfull of sand down the carb after break-in.
  7. stevenp3762
    stevenp3762 BANNED
    1,466
    Feb 7, 2013
    bradenton fl.
    I agree, button it up band run it. Being in Finland might also give more headaches if you tear into it. it looks normal from your Picts.
  8. jpe
    jpe Member
    32
    Dec 2, 2012
    Finland
    Yes you are right about headaches getting getting parts here. I need to order basically everything from Summit and it means about 100$ postage plus 25% taxes and 6% tolling on top of that for every order. So you really do not want to forget anything when ordering.
    Also machining work is quite expensive here, so maybe i'll just bolt my vortec heads on and run it as is for now. With the heads it will be 8.6:1 dynamic compression (10.7:1 static), so we'll see how it holds up.
    All these scratches are in exhaust side of cylinder walls only, so maybe it has been overheated at some point? Pistons are KB hypers with quite tight tolerances. Motor is 383 stroker.
    Thanks!
  9. ZS10
    12,165
    Jan 18, 2003
    BC, Canada
    Good reason to use an air filter.
  10. jpe
    jpe Member
    32
    Dec 2, 2012
    Finland
    Yes, exactly. This motor had K&N filter with K&N top when it bought the car. Now those are replaced by a good quality paper filter but but it seems to be too late.
