Dakota Digital
Discussion in 'Interior Restoration' started by arm2004, Dec 11, 2019.
  1. arm2004
    arm2004 Member
    88
    May 5, 2017
    S.E. Ohio
    I am installing Dakota digital dash and also AAW upgraded wiring harness. Where has everyone mounted the processor box and where did you go though the firewall at (looking at speedometer cable hole). This is on a 70 thanks
  2. giggity
    giggity Veteran Member
    956
    103
    Mar 18, 2013
    Pearland, texas
    you can wire tie it to dash bracket behind gauges. I drilled hole in firewall and put a rubber grommet to protect, I have a few wires and a hard oil pressure line going through
  3. dale68z
    dale68z Veteran Member
    1,364
    22
    May 14, 2009
    Glendale Arizona
    I set mine on top of the ash tray holder.
    I ran my wires through a hole I drilled in the steering column plate. The hole is covered by the plastic scuff plate
  4. DrPepper
    DrPepper Veteran Member
    192
    38
    Aug 29, 2017
    Central VA
    I used velcro and attached the processor to the heater box under the glove box. Also mounted the GPS speedometer in the same location. Easy access if needed.
  5. mrfleet12
    mrfleet12 Veteran Member
    328
    91
    Aug 8, 2014
    West of Chicago IL
    Directly behind the gauges.
  6. arm2004
    arm2004 Member
    88
    May 5, 2017
    S.E. Ohio
    That is where i ended up mounting mine (on firewall behind gauges) also found a firewall boot and used the speedo cable hole to run all cables/ extra wires though. Thanks for the help
  7. bullock
    bullock New Member
    Apr 2, 2017
    i made an aluminum plate that screws on behind the cluster
