Dash Pad Epoxy?
Discussion in 'Interior Restoration' started by 71 Camaro, Apr 7, 2012.
  1. 71 Camaro
    71 Camaro Veteran Member
    1,682
    Jan 10, 2007
    Cedartucky
    Have pulled the warpage out using heat and weights. Now would like to add attachment points underneath. My idea is to grind the heads of some short bolts very thin and then epoxying these underneath, giving me several studs to be used to fine tune the dash, pulling it down where needed as much as needed.
    Has anyone done anything similar? What adhesive did you use? Am debating between 5 min epoxy, JB Weld, or fiberglass resin.
  2. mech393
    mech393 Veteran Member
    760
    Aug 9, 2003
    belvidere illinois usa
    i cut out the squares that should have studs put in at the factory, then i made a sheetmetal square to fit the hole and weld in a screw to the sheetmetal square after that i fiber glassed it in, its been six years and the dash has'nt lifted yet.
  3. 71 Camaro
    1,682
    Jan 10, 2007
    Cedartucky
    That sounds a lot like what I have in mind, but one thing I don't understand, do you mean bolts? I don't see how it would work with screws. Also, why did you remove those squares? I was going to just glue right on those. Maybe I should go look at them again. Thanks for the tip on the fiberglass. Have had good luck with the stuff, but figured something else might be better.
  4. mech393
    760
    Aug 9, 2003
    yes i think i used a 10/32 bolt or screw what ever you wan't to call it as long as a nut will thread on it , and also i used the longer clamps from classic industries to hold down the dash pad.
  5. 71 Camaro
    1,682
    Jan 10, 2007
    Cedartucky
    Sweet! This beats the heck out of replacing it. Getting the hump out really wasn't that hard either. It just isn't lying quite flat. Few fasteners where needed and it'll be perfect.
  6. CamarosRus
    CamarosRus Veteran Member
    Want specific info as to HOW to
    heat up slightly warped pad so i pull down f
    Flat after i install additional small carriage bolts????
  7. nova66mussl
    nova66mussl Member
    95
    Jul 19, 2009
    East Wenatchee, WA
    One to consider is called an elevator bolt. It has a large diameter head that is very thin like a flat washer. You can dremel out a large round hole back from where you want the stud then dremel a small slot big enough for the stud part. Insert into the large hole then slide into the slot.
  8. 71 Camaro
    1,682
    Jan 10, 2007
    Cedartucky
    Not sure I follow what you're saying nova66, but sounds like a good idea, could you elaborate a bit more? You lost me with the slots and hole stuff. I'm thinking of using brackets off a bathroom vanity top on the new studs. I noticed that these sinks are attached very similarly to the dash pad.
    As for pulling out the warp, it was a piece of cake. I have everything out of the dash to refurb it all a bit, so plenty of room now. Took a heat gun and just got it really warm on the back side and it just flopped back down. I shoved everything heavy I could find on top to keep it low as it cooled. Ended up doing it a few times, trying to improve things, but it didn't make a lot of difference. If it resists drawing up evenly, I'll heat it up some more. For the record all the techniques that I used I found here on this forum. If you search for it, you'll find enough reading to keep you busy for an entire evening.
