DCC fan controller FK45 install
Discussion in 'Electrical Systems' started by 73 Z, Aug 12, 2018.
  1. 73 Z
    826
    11
    Jun 9, 2007
    Los Angeles, Ca
    Idling in garage once temp reached 185/90, didn't hear fans yet! Then verified they were indeed spinning. Let idle for 20+ min temp stayed 185/90 yet fans are very quiet compared to running relays and the forgettable switch, Nice! 20180804_164513.jpg 20180805_171743.jpg 20180811_211733.jpg 20180811_211752.jpg
  2. dave@ztech
    2,159
    318
    Mar 27, 2016
    NY
    Could you provide a little more insight , what exactly , does that controller do, different from a relay? And why is it quieter?
    Thanks
  3. 73 Z
    826
    11
    Jun 9, 2007
    Los Angeles, Ca
    From what I know, a relay is basically a switch usually controlled by another switch Its either on or off. My previous electric fan set up was just that either on or off via a switch, and starting/running at 100% you could hear it over the headers and a healthy 383.
    The DCC FK45 starts and runs the fans from 0 to 100% depending on cooling needs. No switch, relays required easy install (pos/neg) to battery and (pos/neg) to fans then insert probe in lower outlet of radiator. I couldn't even hear the fans for the 20min I let it idle in garage, but they where spinning just enough to control the temp and let the 383 take the lead mic.
    Now I need a hydro boost set up, so I don't have to run the annoying brake booster vacuum pump, Also noisy. But I just freed up 2 relays to do the relay conversion for the head lights!
    dave@ztech likes this.
