Deer slayer 81
Discussion in 'Project Progress' started by 80sz, Oct 14, 2016.
  1. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    My names Ryan and here's my 81 z. This build is because I hit a deer for second time. First time was when I just got done with resto 6 years ago . I got on road and few days later I hit deer head on,3000.00 damage. Painter did a hack job and looked bad. I just dealt with it until I decided to get new nose and have it painted. Eh,it turned out worse. I just lived with it again. I guess I got lucky when hit deer last month,I got 4700.00 in ins money this time,bad thing they canceled me until I fix it. They said damage more than 75% of car worth. Also on way home from hitting deer my motor started ticking bad,I lost a pushrod. Now motor shot also. I'm hoping I can fix the 406 block,I haven't had it looked at yet. I think she's done and new block in order. So far I took out the subframe and painted it with kbs frame paint. It turned out okay,had some rookie mistakes that made it less than perfect . I'm overly picky and want stuff exact. My plans are to get a efi gas tank,efi carb and put it on 406. I'd like a super charger with 600hp and a roller cam. Or I'm going to swap in a lsi and build that up with a 5-6 speed.
  2. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg I cleaned with wire wheels and scrubbing.
  3. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg Turned out okay,the paint was thick and went on heavy and I also got some water mixed in even with a filter on it. Now I got 3 filters on it and realized heat is a issue when painting also.
  4. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg Glossy,I'm calling it vadar black
  5. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg Got new steering in! It's a 88 iroc steering gear and new shaft.
  6. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg Got brakes in,had some extra paint and did rotors . That paint sticks to rust amazing.
  7. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg Trim tip,wrap with tape ,no scratches!
  8. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    I got all trim off and start interior removal tonight. I'm getting whole car repainted! I have to kick in some of my money but the ins is mosly covering it! And with the prep I'm doing I will get a primo paint job! I got new rad support from rock auto,it fit perfect. It was almost identical to old one,it even weighed the same. I got that installed also.
  9. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg Spay can semi gloss ,done!
  10. 80sz
    80sz Veteran Member
    2,894
    319
    Feb 2, 2014
    Buffalo,n.y.
    image.jpg First build tear down,this is why I put new door skins on! I was lied to,car was in accident when I bought in 1988. Was rear ended ,found glass under carpet still,scummy liars back in the day.
