Defroster vent install
Discussion in '1970 - 1973 Specific' started by gpm6367, Sep 6, 2019.
  1. gpm6367
    919
    52
    Feb 12, 2005
    New Joisey
    Bubba chopped up my defroster vent so as to hook up a flex hose for the VA system. Ok no problem I’ll just get another duct, right?
    This duct is held on by some type of screw visible through the windshield. (nice design) I don’t see how I can loosen these screws with the windshield in place. Anybody done it?
    And I’m sure that hardware store screw ain’t right. Can someone post photos of an original so I can see what type of screw used in 1970?
  2. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,272
    54
    Jan 1, 2005
    Schererville,In.46375
    They were pinned and not screwed....
  3. jbloake
    jbloake Veteran Member
    350
    85
    May 1, 2002
    Atlantic Canada
    E953A083-5075-406F-A1B7-E67F499E4748.jpeg 1970 Looks like a plastic push in type retainer
    Edit I just read xten’s post #9 and found it funny GM went from plastic to metal. So got the magnet out and sure enough they are metal ! Thanks xten !
    gpm6367 likes this.
  4. gpm6367
    919
    52
    Feb 12, 2005
    New Joisey
    I suppose it’s possible to install a plastic push in pin with windshield in place. Don’t know how I’ll get that screw out.
  5. Rdobbs1977
    Rdobbs1977 Huge Guns N Roses Fan
    342
    23
    Dec 1, 2014
    Nashville
    been there, sort of. when i got my 2nd Gen 5 years ago, it did not have defrost vent or heater. At the time i wanted to put one in and did (since taken it back out). Well, to my amazement, there were two small bolts with nuts in those defrost holes you mentioned. even with half my dash out, i could not get up in there to them best i recall. What i do recall is i had a very, very small saw. Sawed it at the top where window and dash meet. I feel ya pain,
    gpm6367 likes this.
  6. 72'z'steve
    72'z'steve Veteran Member
    1,102
    194
    Oct 15, 2000
    waukesha wi usa
    The duct will stay in place with out the pins,you will just see the open holes which believe it or not many are broken off or missing[I look for stupid stuff like that] way back in the 80's I did a factory a/c to regular heat conversion due to it being so hacked up.I was lucky as you could buy a whole parts car cheap then [which I did] never could get a plastic pin in-tried extended needlenose but duct stayed in with lower screw.I remember finding the push pin-1/8 I think at the hardware store in little drawers back then-hope this helps Steve!!
    gpm6367 likes this.
  7. gpm6367
    919
    52
    Feb 12, 2005
    New Joisey
    Found a near perfect one on epay. Ends are not broken and pins in place. 95B362E1-1714-4622-BE56-7A899E58A8D9.png DA90D44C-6D2B-4061-96A5-13D77B3431DF.png 18B50A0D-C00E-4912-B17B-F25D619E9BED.png 643A65BA-24E7-456E-A7A7-9AD67C627FEE.png Looking at that pin with the retention washer on bottom suggests it sits in place and you pop that washer on from underneath? I can’t see doing that given the space limitations.
    Or does that pin with the retention washer remain as is and just sit in a hole in sub dash?
    Does AIM show it? Yes, I have ordered my own AIM . : )
  8. jbloake
    350
    85
    May 1, 2002
    Atlantic Canada
    EAA4E442-CC56-467F-BBFE-F20C73B35D0C.jpeg I believe you just pop the upper pins in holes and install lower bolt with washer. If you look close under the dust there is a clip nut to hold the bolt
  9. xten
    xten Veteran Member
    3,092
    1,859
    Sep 24, 2014
    Pittsburgh, Pa.
    In my 73 (and I talked to another 73 owner) The push pins were metal, like rivets, which would explain why so many of those ducts are broken. I had my windshield out and couldn't remove them. The head is convex and with the location couldn't drill it out. Put fork tool between vent and metal dash,and busted the vent at both rivets. If I were putting one back in, I would use plastic push pins. Just make sure they're a tight fit so they don't come loose over time.
    gpm6367 likes this.
  10. Budz
    3,113
    123
    Mar 17, 2002
    Ashburn, Va USA
    As far as I know mine ('70 Z/28) are original. I put a small magnet up to them and they are metal. The dash 'pad' is reproduction, so I don't know if the indentation you see is supposed to be there
    No flash
    Flash
    gpm6367 likes this.
