Distributor Stamping Question
Discussion in 'Original Drivetrain Topic' started by clm69z28, Mar 7, 2019.
  1. l16pilot
    1,777
    98
    Dec 13, 2004
    Hurlock, MD, USA
    Good point...I'll give Mike a call on this. Never heard about measuring the O.D., but certainly makes sense. I would expect if a heavy cut were made, the cap would be looser than normal. Would like to get a restamped housing to measure against mine...hmm...I have my 019 and 1-2 other worthless housings from the same era...could certainly compare them with a caliper.
  2. 70lt1z28
    2,911
    472
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Funny about the OD. The distributor that came in my car when I purchased it back in '78 was blank...no numbers stamped. Not turned (folks didn't do that back then) and is actually about 0.002 inch smaller in diameter than my 2019 distributor
    I imagine it may have some value to someone wanting to create a restamped one.
    By the way, sorry to hear about Bud. I never got a chance to meet him but sounds like a nice guy.
  3. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,101
    25
    Jan 1, 2005
    Schererville,In.46375
    I don’t think would effect the cap.. no need to go that high.
    2ndGenCrazy likes this.
  4. 70lt1z28
    2,911
    472
    Oct 3, 1999
    The diameter where the car fits is actually by design a bit smaller. If you turn the base area down far enough to remove the factory stamps, it could go so far as to remove this step altogether which is very easy then to see or if you cut the step down the cap gets loose on the diameter.
  5. ronzz572
    1,929
    52
    Feb 8, 2007
    imperial pa
    That stamp looks good to me. Here is a 9M14 I have. Yes the 0 is better aligned but everything else looks the same. Does it have a MS201 vacuum pod? what is the cam stamp? 20190307_170312.jpg
  6. 70 SS/L78
    2,624
    71
    May 5, 2005
    Rockford, MN
    Delco Remy or whoever made them sure made a lot of 2019 distributors that day!
    Only thing I noticed different in picture of post #1 is that the '019' is offset whereas all the other pictures the numbers seem to be lined up.
  7. COPO
    17,231
    474
    Toronto, Ontario, Canada
    GM sells blank housings. I had to buy one in '85 due to slop on the bushings on my orig housing which I still have and took a photo of it in the post up top. Plus GM didn't stock any shafts in '85 which I would have picked up for a better fit in the new housing.
  8. THNDER
    THNDER Veteran Member Lifetime Gold Member
    1,759
    Mar 18, 2000
    O'fallon, Mo
    All distributors shown , look good to me.
    l16pilot likes this.
  9. Gary S
    21,922
    584
    I agree with THNDER. All the pictures look good to me.
  10. 70lt1z28
    2,911
    472
    Oct 3, 1999
    Thanks Mark. Always wondered where a blank housing would have come from. It has all the right internals (cam, vacuum advance, etc) for the LT-1 just a blank housing. Makes sense now.
