Does Any One Make a Repo Two Hole 74-81 Camaro Inner Fender Well
Discussion in 'Body Restoration' started by Bandit723, Jan 13, 2017.
  1. Bandit723
    Bandit723 Veteran Member
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    I have been looking at the offerings from most of the big players. most seem to offer the universal 70-81 inner fender wells which I am leery of buying.
    Does any one know if there is a correct fender well offering for the 74-81 Camaro's? if so who carries them.
    Thanks for looking
  2. badazz81z28
    16,945
    505
    Las Vegas, NV
    Tamraz on eBay
  3. Bandit723
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Looked at the inner fenders on Tamraz web site. best picture I have seen of these so far. they do show the two holes on the back of the fender well. but from at least at looking at the picture and then comparing to my originals does look to be a bit off.
    I suppose I can try calling them and inquire as to the dimensions. I am a bit concerned that these are being billed as 70-81 Camaro Front Inner Fender Skirt / Wheel Well House w/ 2 Hole Brace. pretty sure the years had a difference in the mounts.
  4. badazz81z28
    16,945
    505
    Las Vegas, NV
  5. Hey G
    Hey G Veteran Member
    519
    Mar 18, 2012
    SC
    Also, the hole locations are completely different for those holes...no two of them line up. I used a later style (original GM) on my '72 and I had to drill new holes for the 3-hole bracket...but all other bolt holes lined up good. Hope this helps.
    G
  6. Bandit723
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Thanks G. yes this does help
  7. Scott51
    Scott51 Veteran Member
    625
    73
    Jan 2, 2012
    New Zealand
    yeah I bought a solid used set from a 73 thinking they were same and was pretty pissed when I went to bolt to my 77 after having them freshly blasted, painted and undersealed (and scrapping my hacked up originals). Found this page afterwards that has the lowdown on the bolt hole locations and other differences: http://www.apiem.com/camaro/InnerFenders20070727.asp
  8. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,244
    46
    Jan 1, 2005
    Schererville,In.46375
    I have NOS 2 hole wheel wells if interested.
