does this look like my intake could be leaking
Discussion in 'Engine Topic' started by cutty, Mar 16, 2012.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    just noticed this today, its on both sides, and only at the runners, any thoughts
  2. CorkyE
    10,435
    504
    Did you use thread sealer on the bolts.
  3. cutty
    342
    Dec 12, 2008
    ontario canada
    should did
  4. cutty
    342
    Dec 12, 2008
    ontario canada
    forgot to ad, i had a vac gauge on it, and it holds pretty steady at 9 inchs of vac
  5. cutty
    342
    Dec 12, 2008
    ontario canada
    any thoughts or input?
  6. soco200p
    soco200p Veteran Member
    374
    Feb 22, 2004
    Chicago burbs', Illinois
    Oil leak maybe? It looks like the gasket is sticking out quite a bit from your valve cover
  7. Marks71BB
    11,833
    Aug 25, 2002
    Gods country in the beautiful Sierra Mountains of
    Is there any performance issues?
  8. K5JMP
    10,216
    9
    Oct 19, 2006
    MORTUORUM VENATOR - Z.R.T.
    I had the same 1st thought.. old school cork is easily overtightened, even with load spreaders.
  9. vegafish33
    vegafish33 Veteran Member
    280
    Jul 25, 2008
    Montreal
    +1 on valve cover gasket
  10. cutty
    342
    Dec 12, 2008
    ontario canada
    not the valve cover gasket, know that for sure, im gonna just pop it off tomorrow and see, problem i started having is it starting to get hot real fast, ive checked all the plugs and they look ok, and motor seems to be running really lean the last couple days,thought it might had been the carb but had it rebuilt, ill snap a couple pics tomorrow once i got it off
    oh yah, if you look real close at my valve cover, i had to trim it aLittle when i was running a team G intake,
