does this look like my intake could be leaking
Discussion in 'Engine Topic' started by cutty, Mar 16, 2012.
  1. cutty
    cutty Veteran Member
    342
    Dec 12, 2008
    ontario canada
    ok got it off, here are the pics
  2. soco200p
    soco200p Veteran Member
    374
    Feb 22, 2004
    Chicago burbs', Illinois
    Is it oil or fuel that is soaked in? If it's oil, I've got to stick with my first post that it's the valve covers leaking. It looks like the valve cover gaskets are crooked where the bolts are, plus you mentioned you cut the covers which is going to compromise the seal.
  3. my24ktrat
    my24ktrat Veteran Member
    1,226
    Jul 5, 2007
    Roch., NY
    ...I say valve covers also , when the revs go up so does the crank pressure to squeeze/seep out some oil, try another set of valve covers, just my .02, DC:bowtie:
  4. cutty
    342
    Dec 12, 2008
    ontario canada
    and smells like gas, and wouldnt have some oil in the runners?
  5. soco200p
    374
    Feb 22, 2004
    was the engine running ok? if it's fuel it could possibly be a warped intake that was causing the fuel to leak, but that looks pretty bad and if it was, the engine likely was running pretty poorly.
    I'd get some new valve covers, and put on fel-pro intake gaskets. I bet that will solve the problem.
  6. gregs78cam
    gregs78cam Member
    51
    May 2, 2004
    Spirit Lake, ID
    Looks to me like you have oil wicking through your intake gasket. That would also explain the oil in the intake ports. You have cast aluminum valve covers right? Unless the rails are bent they not likely to leak. Try better quality intake gasket, maybe smear a thin film of Right Stuff on the bottom edge that would be in contact with oil when you reinstall them. Also make sure your PCV is working.
  7. Twisted_Metal
    26,948
    928
    Looks like the intake bolts may have been torqued on the ends first. (Instead of the middle first.)
    Lay a straight edge across the sealing surface of the intake to be sure it's flat.
