Door glass gap
Discussion in '1978 - 1981 Specific' started by 80sz, Aug 27, 2019.
  1. 80sz
    80sz Veteran Member
    3,143
    411
    Feb 2, 2014
    Buffalo,n.y.
    What is the proper gap distance from b pillar to glass edge? 1/2”?
  2. grzewnicki
    3,262
    101
    Dec 9, 2009
    Gordon from Jacksonville Fl
  3. Smokey15
    Smokey15 Veteran Member
    2,978
    1,183
    Aug 13, 2017
    Caledonia, MI
    Thanks for re-posting that. The passenger side window on my wife's '71 Z is giving me a hard time.
  4. badazz81z28
    16,375
    406
    Las Vegas, NV
    I have noticed, there is more of a gap with reproduction glass. I have about 1/4" on the passenger side with original glass and nearly a 1/2" on the driver with reproduction.
    80sz likes this.
  5. 80sz
    80sz Veteran Member
    3,143
    411
    Feb 2, 2014
    Buffalo,n.y.
    That’s my case, pass is 1/2” back and window is set back all the way on adjustment. Driver is 1/4” back. I’ll measure glass, that’s what I was thinking they are different length.
  6. CDesperado
    3,502
    51
    Oct 1, 2004
    Dallas Texas
    On behalf of every Second Gen Camaro owner ever, I would like to punch the Engineer who designed our windows. Getting those adjusted property is a PITA.
    My repop glass was exactly the same measurements as my OEM glass.... but adjusting the different alignment guides was brutal. At a certain point I just had to say it was good enough.
    80sz and Smokey15 like this.
  7. Smokey15
    2,978
    1,183
    Aug 13, 2017
    Caledonia, MI
    I'm still having issues with the passenger side on wife's Z after working on it today.
  8. 70 Proof
    70 Proof Veteran Member
    533
    54
    Sep 28, 2014
    Southern Utah
    Ditto ^^^^^^
    My right side original window goes from 1/4" at the bottom to 1/2" at the top.
    My left side original window goes from 1/4" at the bottom to 5/8" at the top. The variations are due in part to the slight curvature of the glass but mostly due to adjustment.
    I've adjusted my windows several times using the window adjustment guide trying to get them to fit snug against the weatherstrip all around but still come up short, I currently have about a 1/4" gap in one section along the top edge of the glass with the windows rolled all the way up. When I think I have the window adjustments dialed in and re-install the door panels and top rail I discover a less than perfect alignment at the top or front edges of the glass. I suspect Part of the problem is when the top rail in re-installed it tends to throw the window back out of alignment in or out which in turn alters other aspects of the window adjustment. I hope you have better luck with your windows.
