Door hinge pins and bushings, whew
Discussion in 'Body Restoration' started by tom3, Apr 30, 2019.
  1. jbloake
    jbloake Veteran Member
    349
    80
    May 1, 2002
    Atlantic Canada
    This is a better picture,I cleaned 45+years off my used 1970 nylon bushings .The color is natural
  2. Bandit723
    Bandit723 Veteran Member
    3,148
    464
    Oct 1, 2016
    Waupaca WI
    Wow i would never of thought that nylon was used for these....
  3. xten
    xten Veteran Member
    3,080
    1,849
    Sep 24, 2014
    Pittsburgh, Pa.
    Was wondering if it mattered where it was built if it got copper or nylon, or if year came in to play. I've replaced many and never ran into nylon. Just wanted to add there are (or were) oversize bushings available, which are good for elongated holes, Just step-drill the hinge till the bushing fits snug. Much better alternative to replacing hinges, especially the weld-on hinges.
  4. krabben1
    8,185
    52
    May 16, 2007
    ( . Y . )Delco
    So,I wonder if the plastic bushings were a carryover from the first gens,then they realized these new doors were heavier?
  5. 70lt1z28
    3,474
    690
    Oct 3, 1999
    Beavercreek, Ohio, USA
    My 04B Norwood car had them.
    Possibility on the first gen theory.
  6. thesalboy
    thesalboy Veteran Member
    358
    124
    Mar 25, 2017
    Los Angeles, CA
    Anyone know of a source for just the beefier of the brass bushings?
  7. dave@ztech
    3,504
    717
    Mar 27, 2016
    NY
  8. dave@ztech
    3,504
    717
    Mar 27, 2016
    NY
    Instead of shelling out for all-new, application-specific hinges, you can purchase a hinge-pin kit for any Chevy square-body pickup and use those to rehab your worn hinges. Second-gen Camaros use a similar hinge pin to the one in the pickup, but with smaller bushings. Simply putting new Camaro hinge pins into an old door usually won’t fix the problem because over time the bushings will spin in the steel hinges and open up the hole. That’s what causes the doors to sag, and just putting in new pins and bushings of the same size won’t solve the issue. Instead, you can ream out the holes in the hinges to accept the larger bushings and square everything back up.
  9. thesalboy
    358
    124
    Mar 25, 2017
    Los Angeles, CA
    That's pin and bushings. I have pins, and am just looking for bushings. Would cost m $40 to get all the bushings via pin/bushing kit. Cannot be that much $$$ for some bushings.
  10. thesalboy
    358
    124
    Mar 25, 2017
    Los Angeles, CA
    GIMME BIG BUSHINGS YEAH!
