Door insulation - how thick
Discussion in 'Interior Restoration' started by Chuck71RS, Nov 9, 2019 at 12:12 PM.
  1. Chuck71RS
    1,419
    174
    Nov 24, 2012
    Houston, Texas
    Putting 78 door panels in my 71 and 6 of the 10 fasteners are the two part type, metal post in door panel and plastic plug in the door metal. 1/4" close cell foam insulation is to thick for these fasteners
    How thick can insulation be?
    What is good for noise reduction? Give the door a more solid sound when closed
  2. CDesperado
    3,534
    53
    Oct 1, 2004
    Dallas Texas
    I used second skin sparingly then used 1/8" CCF. I originally also had 1/8" foil thermal barrier but had to remove it because like you said, it was too thick.
    Chuck71RS likes this.
  3. Chuck71RS
    1,419
    174
    Nov 24, 2012
    Houston, Texas
    Thanks for the good info. Now I have numbers (thickness) to work with instead of trial-and-error
    Can you provide some detail where on the door panel you applied second skin?
    What brand of 1/8" ccf did you use? Does it have an adhesive backing? Why did you use ccf on top of second skin
    As part of my door insulation, will apply 1/4" ccf to the GM door concave stamping. Tested earlier in the rebuild and it made a noticeable improvement
  4. CDesperado
    3,534
    53
    Oct 1, 2004
    Dallas Texas
    I will post some pics tomorrow - it will make more sense with the pics
