Door Opening Clip
Discussion in 'Body Restoration' started by Oldskool62, Nov 2, 2017.
  1. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Hi All
    There is some sort of clip or little bracket in the top front of the door opening that sticks out when the window is closed. Is it needed? Mine on both sides are pitted with surface rust. This isn't my car but it shows the clip/bracket I'm talking about.
    Cheers
  2. Gary S
    22,782
    916
    Window blow out clips is what we call them. They are there to prevent the windows from leaning out at higher speeds. Without them, you get a lot of wind noise as the window pulls away.
  3. Twisted_Metal
    27,305
    1,122
    The blow-out clips are riveted to the weather strip channel.
    The clips are reproduced but I don't know if they include replacement rivets.
  4. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    Thanks Guys much appreciated.
  5. sprink
    sprink Veteran Member
    533
    154
    Apr 27, 2008
    ffx, va
    I plasti-dipped mine. Little tougher to clean up & do on car though.
  6. Burd
    620
    118
    Oct 6, 2011
    $hitty Part of Detroit
    There are diff types, a guy gave me a set, turns out they are for 67-69. I'm looking for the correct type too.
  7. Oldskool62
    Oldskool62 Member
    51
    10
    Sep 29, 2017
    I'll take a look around and buy an new set.
