door panel rust preventer
Discussion in 'Body Restoration' started by 73z28cam, Jun 1, 2019.
  1. 73z28cam
    73z28cam New Member
    15
    Feb 3, 2013
    Des Moines, IA
    I had to replace a 2 x 3 area in the lower rear of the door, rusted from the inside where the inner panel and outer panel touch. I have also noticed surface rust developing on the "rolled" section of the door, i assume it exists on all three sides.
    Question is, what has anyone used to seep between the roll to stop/prevent further rust, beside replacing the outer panel.
  2. CDesperado
    3,466
    41
    Oct 1, 2004
    Dallas Texas
  3. dave@ztech
    3,253
    653
    Mar 27, 2016
    NY
    what about that cavity wax?
    hubedobeedo likes this.
  4. 8pack
    2,580
    144
    Aug 29, 2007
    Pittsburgh, PA
    If there is not any oil in there POR 15 is like water and you could pour that in there or squeeze it in with an eyedropper or small baster.
    Alternatively, Gibbs oil can be sprayed in and it says you can paint over it. It evaporates eventually and leaves a barrier. Fluid film will also seal it but it is lanolin based. Both will need to be reapplied periodically. You could fill it with a paint or as suggested a cavity wax and then apply the gibbs oil to ensure everywhere gets penetrated.
    http://www.roadsters.com/gibbs/
    http://www.gibbsbrandlubricant.com/
  5. 73z28cam
    73z28cam New Member
    15
    Feb 3, 2013
    Des Moines, IA
    I think I will try the Gibbs oil and see if it will seep into the seams and the prime and the rust proof
  6. hubedobeedo
    hubedobeedo 3rd times a charm
    400
    127
    Jul 18, 2013
    Huntertown,IN
    rust check out of canada is a nice seeper it looks like tranny fluid
  7. Scott51
    Scott51 Veteran Member
    612
    69
    Jan 2, 2012
    New Zealand
    Gibbs is great stuff but not right for this application, likewise for Rustoleum, POR15 or anything other paint. Cavity waxes are developed specifically for this purpose, used by most modern auto manufacturers and definitely the way to go
  8. Happy_Dan
    Happy_Dan Veteran Member
    886
    139
    Sep 13, 2013
    New Boston, NH
    My friend who is a body man says not to fool around with the doors on my car. I have a little surface rust in the corners where it rolls over and he insists I should reskin them. I'll figure that out someday when I get that far!
  9. dave@ztech
    3,253
    653
    Mar 27, 2016
    NY
    Who would be reskinning them , you or the bodyman? If you can just knock off the rust and prime and paint ,that would , should work
