door rubber bumpers
Discussion in 'Body Restoration' started by Chuck71RS, Oct 31, 2019.
  1. Chuck71RS
    1,482
    187
    Nov 24, 2012
    Houston, Texas
    How are the bumper posts inserted into the door? On the interior bumper surface is a hole over each post. Is it insert something with a flat surface and push?
  2. l16pilot
    1,847
    138
    Dec 13, 2004
    Hurlock, MD, USA
    Yes, and it helps to lube the insert first. But be careful, push too hard and it'll break through the rubber....I swear I AM talking about the door bumpers! Seriously, I took a cheapo small phillips screwdriver that fit the bumper hole nicely, cut off the Phillips end, rounded it slightly on a belt sander and it worked well.
    Chuck71RS and dave@ztech like this.
  3. Ricks72Z28
    Ricks72Z28 Veteran Member Lifetime Gold Member
    1,244
    46
    Jan 1, 2005
    Schererville,In.46375
    Or just toss them under a heat lamp to soften them up.....both ways work great.
    Chuck71RS likes this.
  4. COPO
    17,906
    766
    I use a small flat blade screwdriver.
