Door Spring Compressor... FTW!
Discussion in 'Tips 'n' Tricks Topic' started by Twisted_Metal, Nov 6, 2016.
  1. Twisted_Metal
    25,389
    330
    If you ever need to change out the hinge pins and bushings in your doors....
    I needed to replace the bushings in my Jimmy door. (Same pins springs and bushings as a 2nd gen Camaro, I believe.)
    Forget compressing the spring with a vise and using wire or zip ties.
    I've done it both ways before and even suggested it here.
    I decided to pay my local O'reilly's a visit and picked up the compressor tool for $8.
    The instructions on the package say to use a 1/2" wrench.
    Nope... The tool has a 13MM nut on it.
    (Must be old packing instructions, prior to being made with a Metric nut.)
    Just jamb it into the spring and tighten the nut until the spring is free.
    Reverse the procedure for re-installing!
    Probably the best $8 I've ever spent!
    It made the job of dealing with removing and installing the hinge detent spring a breeze? :happy:
  2. Green hornet
    Green hornet Veteran Member
    1,027
    134
    Oct 11, 2015
    North Bay, CA
    I have used that tool for years. Your correct best $8 bucks you can spend.
  3. John Wright
    13,956
    48
    Aug 9, 2002
    Rustburg, Va
    The springs on my son's blazer must be a lot tougher than the ones on a jimmy. I bought one of those at Advance Auto and tried to use it...before the spring was compressed enough to get it out of the door it folded. I used a more expensive one made by snap-on(not sure about the mfg, I borrowed it) that was a forged piece and it worked flawlessly.
  4. Twisted_Metal
    25,389
    330
    Jimmy and Blazer door springs should be the same.
    I looked at an old Monte hinge in my garage and those looked to be the same size too. 1" diameter and 2.5" long.
    I worried this one would fold but it was tough enough to compress the spring down to 1.5".
    More than enough to slip it out and back into place. (1.75" will do.)
  5. Ihada70Z28B4
    Ihada70Z28B4 Veteran Member
    134
    11
    Oct 4, 2002
    Buffalo,NY,USA
    Harbor Freight has the same one, can't remember what it cost as I have had it for a few years. I used it twice yesterday on the camaro and it worked great.
  6. Gary S
    20,806
    223
    Apparently the word isn't out yet that Chinese and Japanese 1/2" isn't the same as US 1/2"? :)
  7. azkeebler
    azkeebler Veteran Member
    569
    Dec 14, 2011
    Manteca, ca.
    I don't have a pic, and your compressor looks to work better, but I recently used a valve spring compressor with the turn knob and it worked great on my firebird hinges. I had it laying around from past valve seal work.
  8. 70pete
    70pete Member
    71
    Aug 19, 2014
    martinsville, nj
    just bought one at Advanced Auto, $11.99. Worked great
    azkeebler likes this.
  9. CamarosRus
    CamarosRus Veteran Member
    I bought the STECK brand of (above) spring compressor from the AMAZON site.
    Made in USA......Worked Great......$13
