Drag Radials; Hoosiers or ET Pro?
Discussion in 'Competition Camaros' started by TheMeat, Mar 26, 2014.
  1. TheMeat
    TheMeat Veteran Member
    970
    Feb 9, 2007
    Ol' Miss.
    Getting ready to purchase a new set. I've heard nothing but good reviews about the Hoosiers other than a short life span. The New ET Pros seem to be a good choice as well. Looking for some opinions. Car is ~3700 w/ me, Cal Tracs, and split mono leafs with adjustable rears, auto, Whipple Blower, 3.70 gear 9", 610rwhp/670 rwtq. These tires will be strictly track use only. 275/60/15.
  2. turbodarryl
    turbodarryl Veteran Member
    356
    Dec 22, 2012
    Walker, La. Hometown NOLA
    As far as I've seen an read the new MT ET Pros would be my choice for a drag radial with the Hoosier a very close 2nd
  3. Turbo T/A
    Turbo T/A Veteran Member Lifetime Gold Member
    4,207
    Apr 8, 2002
    Ottawa, Ontario, Canada
    Hoosiers have a very little lifespan. I wore a god damn set on the street testing from Mon-Friday! Had to order another set on the Wed so I would be able to get to the track that Sat!
    M/T has served me well. Went 9.4X @ 144+ on 17" D/R
  4. sponge003
    sponge003 Veteran Member Gold Member
    1,510
    Jan 10, 2009
    Concord, NC
    I just started running the ET Pro, like it so far!!
  5. newschool72
    newschool72 Veteran Member
    1,185
    Feb 25, 2011
    forsyth,ga
    I haven't even heard of ET Pros. Are they MTs version of the track only DR ? AS in the no tread type? With a properly set up suspension, the MT drag radial (the one you can run on the street) will hook some amazingly fast cars. Cars with a lot more power than you are putting down at the current boost level AND you don't have to change back and forth. They drive very well on the street with 30 lbs of pressure. Air them down to 16-18 at the track and hook hard!
    What size rear brakes are you running? If you can clear a 15" wheel you would be golden with a set of MT street DRs. If you are stuck running a 17" wheel, the track only DRs or slicks are a better choice, IMO.
  6. 383Camaro79
    383Camaro79 Veteran Member
    806
    Feb 11, 2000
    Alton, IL, U.S.
  7. sponge003
    1,510
    Jan 10, 2009
    Concord, NC
    Pros have almost no tread
  8. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    Alright.. Pro's it is!
  9. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    I have the Wilwood's on the rear..can't remember the diameter (too many numbers in my head).
    But a 15" will fit, no issue. Knew I was going to take this car to the strip and sidewall would be my friend.
  10. TheMeat
    970
    Feb 9, 2007
    Ol' Miss.
    Your car is working good!! :cool:
    What's the suspension set up?
