Drainbolts Muncie stuck!
Discussion in 'Transmission & Driveline Topics' started by Seemank, Mar 30, 2017.
  1. Seemank
    Seemank Member
    76
    Sep 12, 2013
    Norway
    Hello good people!
    Im trying to loose the oilbolts for draining and filling my '73 Muncie M21.
    They are completely stuck..Any tips? How bout threads, normal direction to loose/tight?
  2. Double J
    Double J Veteran Member
    411
    15
    Jan 23, 2008
    Michigan
    NPT thread Rigthy Tighty Lefty Loosey
  3. Dave Nelson
    Dave Nelson Veteran Member
    4,418
    2,269
    Dec 19, 2003
    Vineland N.J USA
    Try a little heat, normal direction (counter clockwise) to remove.
  4. Seemank
    Seemank Member
    76
    Sep 12, 2013
    Norway
    Tnx, turned out it was just a question of brut force And now comes the next question: How is the old oil suppose to look like? It was a bit shimering and thick. Also some realy greasy stuff on the magnets on the oilplugs. No big bits, though.
  5. COPO
    17,930
    784
    Sounds normal. You will get filings from the shift fork wearing and the thrust washers. Thick stinky dark gear oil is the used look.
    Seemank likes this.
  6. CorkyE
    10,403
    485
    That oil is 90W or more, so it's going to be thick, especially when drained cold.
    Seemank likes this.
  7. Fbird
    4,069
    661
    Feb 12, 2011
    atlanta, ga
    ah... the smell of sulfer....mmmmmm....
    btw the ONLY way to get rid of that WONERFUL smell...that you got on your shop pants.... ADD VINEGAR to your wash... ;)
    Hey G and Seemank like this.
  8. COPO
    17,930
    784
    Factory is 80w90. Same oil gets in the rear axle + a bottle of posi additive if you have posi.
  9. Gary S
    22,596
    812
    Similar oil. Tranny should have GL4 rated 80W-90 and rear end can use either GL4 or GL5 rated 80W-90.
  10. COPO
    17,930
    784
    I use GL4 and GM still sells it. I ran GL5 in my Muncie for many years with no ill effects to the GM syncros. The syncros still looked new so the
    tale about eating your syncros is a myth IMO.
