Drilling holes? Good ideas? Frame
Discussion in 'High Tech Retrofits' started by badazz81z28, Jan 30, 2006.
  1. badazz81z28
    16,922
    502
    Las Vegas, NV
    I got my crossmember for my T56 all situated the problem is I need to bolt it in. Does anyone have any ideas? I was thinking of drilling holes in my floor pan so I can drill the frame accuratly. Good idea? bad? Thoughts please
  2. MikeM79
    MikeM79 Moderator Lifetime Gold Member
    7,022
    Mar 5, 1999
    East Quogue, NY
    The easier way is to cut rectangular holes in the bottom of the frame rails then drill straight up through the top of the frame rail....just like the factory did. You just need to make the existing holes longer. You can weld up the excess if you are paranoid....I never did and my stuff has held together.
  3. Aceshigh
    26,757
    Apr 9, 2001
    Boondocks
    Mike, do you have any pics of how you got the AC compressor to fit ??
    Did you notch out your Kmember too ??
  4. badazz81z28
    16,922
    502
    Las Vegas, NV
    The probelm I was thinking I would run into was miscalculating where the holes already exist in the crossmember.
  5. badazz81z28
    16,922
    502
    Las Vegas, NV
    Ended up drilling small holes in the floor. Than I filled them with a tar type substance.
