Drive Shaft Universal Joints
Discussion in '1978 - 1981 Specific' started by typeomang, Jan 11, 2019.
  1. typeomang
    typeomang Veteran Member
    185
    May 25, 2011
    okc, ok
    I have checked the search archive and can not pull it up. Did 1980 universal joints have plastic injected into them or did they just have the inside clips?........1SG(ret)
  2. jamieg285
    jamieg285 Veteran Member
    1,286
    10
    Jul 15, 2004
    Luton, England
    Can't help for definite, but my '79 had injected plastic.
  3. Gary S
    21,923
    585
    Look for retaining clips, both inside and outside. If they aren't there, take a propane torch to it and see if plastic bubbles out. If you are replacing the U joint anyway, heating it won't hurt it.
  4. badazz81z28
    15,994
    336
    Las Vegas, NV
    3R joints in all the later Camaros had injected plastic to retain the caps. Aftermarket 3R joints have clips on the inboard side of the U-joint cap. 1310/1330/1350 have outboard retaining clips. Based on what I have seen, the 70-81 Camaros only used 1310 (early Camaro) and 3R joints (Later Camaro)
    To remove the factory 3R joints is to heat them and melt the plastic out. A real pain the arse! Be careful too...I have had caps fly off.
  5. typeomang
    185
    May 25, 2011
    okc, ok
    awesome, thank you guys, I went ahead and replaced the straps and bolts for the rear u joint.
  6. Gary S
    21,923
    585
    The plastic injected ones are quite easy to remove. Lay the driveshaft on a block of wood on the floor. Heat it with a propane torch until the plastic starts to bubble out of the injection holes. Then, simply smack it with a hammer and bolt on the end cap and it pops out. Before you do that, put on a welding helmet with a clear lens and a jacket to protect your face and arms from the heated plastic squirting out.
  7. Scott Sievers
    Scott Sievers Veteran Member
    204
    88
    May 22, 2018
    SE Iowa
    YEP! heat it too much it will POP really loud and spray you with napalm... Yes... I have.... so wear that face mask!
