Drive shaft
Discussion in '1970 - 1973 Specific' started by Todd Reich, Sep 28, 2019.
  1. Todd Reich
    Todd Reich Member
    49
    Sep 26, 2019
    Looking for info about the driveshaft. Markings, ID stampings, ect. I was wire brushing the rust and these 4 spots stood out. Makes me think there was paint or something. A group of 3 marked by the dukes and 1 at the screwdriver.
  2. Todd Reich
    Todd Reich Member
    49
    Sep 26, 2019
    I also noticed this on the splines. A gap.
  3. bodymanbill
    bodymanbill Veteran Member
    1,278
    630
    Feb 1, 2007
    South Park Pa
    image.jpg The stripes were there to let the guys on the assembly line know what one to put in what car. Stripes were different depending on the drivetrain. Here's mine for my 73 Z with an automatic, put them back in the original spots but kinda winged it on the colors from pics of other ones. Pretty sure there are a couple post on here about the colors and measurements.
  4. shanghai Kid
    shanghai Kid Veteran Member
    179
    80
    Jul 5, 2010
    Uh, I believe the "gap" on the spline you speak of is called being "keyed", which means there is a corresponding tooth on the mating "male" end, or rather the output shaft--correct me if I'm wrong....
  5. Todd Reich
    Todd Reich Member
    49
    Sep 26, 2019
    I think you're right. I am going to check tonight when I get back home.
  6. Todd Reich
    Todd Reich Member
    49
    Sep 26, 2019
    Is that tape or paint? I did take measurements. Any sites that have that color decoding info?
  7. bodymanbill
    1,278
    630
    Feb 1, 2007
    South Park Pa
    image.jpg Its paint, heres a post that has some good info.
    hubedobeedo likes this.
  8. Todd Reich
    Todd Reich Member
    49
    Sep 26, 2019
    Bodymanbill, is there a link to read?
    Also. Any idea if there is a number stamped and if so ,where about?
  9. 74Z28GC3
    74Z28GC3 Veteran Member
    1,685
    44
    Sep 1, 2000
    North Pole, Alaska
    bodymanbill likes this.
