Drive train options - L94/L99 + 6spd or 383 + 700r4
Discussion in 'Engine Topic' started by BrewInfusedYeti, Oct 24, 2019.
Tags:
  1. BrewInfusedYeti
    BrewInfusedYeti New Member
    23
    Oct 2, 2019
    I'm trying to hone in on my drive train for my 2nd gen Camaro. I have a 383 stroker on the engine stand right now and a 700r4 core that needs a rebuild. I am bouncing between keeping the 383 and trying to rebuild the 700r4 myself with a monster transmission rebuild kit or a b&m trans kit.
    OR
    There is a salvage yard in town that has a L94 6.2liter out of a GMC truck with 57k miles. They are looking for 3k for the motor (it runs no issues) and from what I have read its very close to the L99 (different intake, oil pan, accessory mounts). I'd pair the motor with a 6spd out of a 2012 Camaro that has similar mileage. With this route there would be other costs to support the LS motor - radiator, fuel lines, computer/ecu.
    The rear end is locked in at this point (Currie 9" with 3.70 gears). Goal is a fun/reliable street car that I can take on short road trips to the car shows in the area. Off hand the LS combo seems like it might be the more reliable route. I built the 383 nearly a decade ago and so far it runs fine on the test stand - it is not a roller cam which is a downside of this block.
  2. 1980RS
    1980RS Veteran Member
    3,517
    637
    Jun 17, 2006
    MN
    Let's see here?, 6.2 for 3K +another 2K for an intake, ign setup, big dollar headers or a nice 383 that can be built on the cheap, Humm.... A for reliability both are reliable. after all the SBC has been around since 1955 and the LS has been around since 1997. Tough decision.
  3. BrewInfusedYeti
    23
    Oct 2, 2019
    If I stick with the 383, is it worth rebuilding the 700r4 myself or should I look towards buying a rebuilt 700r4 from summit or jegs?
  4. 76z28
    76z28 Veteran Member
    2,052
    51
    Jun 29, 2009
    bakersfield
    Why not pair the 6 speed with the 383?
    The 700r is not great for a powerful engine...
  5. BrewInfusedYeti
    23
    Oct 2, 2019
    The 700r4 was the last transmission that does not require an external transmission controller. 4L60E, 6L80E, & beyond require an external transmission controller that can cost up to 1k. The ECU with the LS motors typically handles the transmission shift points (to my knowledge/understanding). Feel free to set me straight if i'm misunderstanding how I would mate a 6L80E with the 383 stroker.
