Driveline angle issue?
Discussion in 'Transmission & Driveline Topics' started by ULTM8Z, Dec 1, 2019.
  1. ULTM8Z
    ULTM8Z Veteran Member
    9,316
    455
    May 19, 2000
    Los Angeles
    I'm getting this weird vibration when I punch it off the line...
    At first I thought it may be the gear vendor hitting the chassis, but I pulled it out the other day and there's actually quite a bit of clearance.
    http://nastyz28.com/threads/transmi...terchange-or-does-anyone-have-a-spare.327738/
    Seems like it would have to rip the transmission mount apart to span that distance and hit the chassis.
    I'm starting to wonder about the driveline angle. With the shortened driveshaft and all...
    It only seems to do this in first gear when I get the most axle wrap. Feels like it's coming from near the middle or back of the car...
    As of now, the engine/transmission is tilted down toward the rear by 4 deg.
    What should I be looking for in trying to diagnose this?
  2. ULTM8Z
    9,316
    455
    May 19, 2000
    Los Angeles
  3. tom3
    tom3 Veteran Member
    12,229
    413
    Aug 1, 1999
    ohio
    Not sure of your suspension set up but those leaf springs will wrap up quite a bit and the pinion angle changes with it. The old slapper bars used to be the fix for wheel hop and also some control for that angle change too.
  4. xten
    xten Veteran Member
    3,183
    1,979
    Sep 24, 2014
    Pittsburgh, Pa.
    Do you have the front of your leafs clamped? Any type of traction aid? If you find your pinion angle is high, you could start with shims, but that will not stop your springs from wrapping up. Ideal angle of the pinion and crank lines should be parallel. Should never intersect.
  5. 80sz
    80sz Veteran Member
    3,237
    449
    Feb 2, 2014
    Buffalo,n.y.
    Tremec has a app for drive line angle
  6. John Wright
    14,716
    216
    Aug 9, 2002
    Rustburg, Va
    Yup, I used that app when I made the crossmember for my T56 install. Worked good, no vibrations at any speed.
    Mike,
    Lakewood used to make tapered shims to adjust the pinion angle. I used them when I put Ford 9" in my S10 years ago.
  7. xten
    xten Veteran Member
    3,183
    1,979
    Sep 24, 2014
    Pittsburgh, Pa.
    Funny you should mention that. Did the same years ago. I figured out I wanted 2° and had 2"lowering blocks milled at that angle
  8. ULTM8Z
    9,316
    455
    May 19, 2000
    Los Angeles
    Yeah, that's what I'm wondering about... I don't recall this vibration until after I swapped out the torque converter (which now is delivering a lot more power to the rear wheels off the line).
  9. ULTM8Z
    9,316
    455
    May 19, 2000
    Los Angeles
    Nope, everything about the springs is bone stock except for the Herb Adams mod front brackets.
    Yeah I'm hoping its something simple like adding shims...
  10. ULTM8Z
    9,316
    455
    May 19, 2000
    Los Angeles
    Found it, thanks!!
