Driveline angle issue?
Discussion in 'Transmission & Driveline Topics' started by ULTM8Z, Dec 1, 2019.
  1. hubedobeedo
    hubedobeedo 3rd times a charm
    518
    164
    Jul 18, 2013
    Huntertown,IN
    probably because other structure mods were made, GM engineered their vehicles for specific reasons. we modify them for other use ,that needs to be taken into consideration.if removing factory brace what are you replacing it for intended use?space restriction should not dictate from structural integrity . could lead a eventual failure.
  2. hubedobeedo
    518
    164
    Jul 18, 2013
    Huntertown,IN
    i am assuming you have checked with a protractor need 180 degree phasing up and down also make sure it is in correct line side ways, if you have the drive shaft in phase then it is probably a problem at the other ends (tran or rear) . i am only guessing about were it is but it sounds like maybe output shaft bearing or the tail shaft it self.good luck questions are good.any play in the pinion?
  3. hubedobeedo
    518
    164
    Jul 18, 2013
    Huntertown,IN
    i am using a hotchkiss adjustable sport bar have not had the car on street under own power ,but the reason i am using this setup is for future use besides straight line.have done other mods to rear suspension
  4. ULTM8Z
    ULTM8Z Veteran Member
    9,312
    453
    May 19, 2000
    Los Angeles
    Is that bar supposed to curb axle wrap?
  5. biker
    biker Veteran Member
    1,142
    150
    Dec 7, 2014
    New Liskeard Ontario Canada
    I agree, I don't like the look of traction devices either. However, I am sure that a spring pack can easily be engineered to resist axle wrap while still maintaining good ride. I know i have read that somewhere.
  6. hubedobeedo
    518
    164
    Jul 18, 2013
    Huntertown,IN
    its a sway bar,i have made shock plates and moved both shocks inboard to the rear.not the same as a caltrac setup,which is a good fix for straight line.but i want something that is more versatile and does not protrude under the car.that said it should help .i am also running a detroit locker in the 9 inch diff.i will find out if it works!
  7. G72Zed
    G72Zed Veteran Member
    1,344
    370
    Sep 8, 2015
    ULTM8Z, looks like your still struggling with this issue, I would suggest you re-read my post, #14, the answer is right there. I will go 1 step further for you.
    1- Landrum Leaf's, - Start with # 21-342SP D or A.
    2- Allstar Bolt on/Adj. leaf pads - #ALL56127
    3- PTFbody.com, sponsor here - OCS-448 , Spher-o-bushings
    Install these parts, adjust your pinion angle, weld perch pads once set, your done.
    Dave Nelson likes this.
  8. biker
    1,142
    150
    Dec 7, 2014
    Solid answer right there.
  9. ULTM8Z
    9,312
    453
    May 19, 2000
    Los Angeles
    One thing I haven't checked that I need to is the lateral alignment between transmission output shaft and the differential pinion. Hopefully if I get some time this weekend.
  10. 80sz
    80sz Veteran Member
    3,237
    449
    Feb 2, 2014
    Buffalo,n.y.
    I think you need better springs also, I had wheel hop, new springs, no wheel hop. Mine are custom works.
