Driveline angle issue?
Discussion in 'Transmission & Driveline Topics' started by ULTM8Z, Dec 1, 2019.
  1. ULTM8Z
    ULTM8Z Veteran Member
    9,316
    455
    May 19, 2000
    Los Angeles
    I'm getting old I guess... lol. I like having a smooth running, relatively quiet car...
    berg2695 likes this.
  2. biker
    biker Veteran Member
    1,154
    150
    Dec 7, 2014
    New Liskeard Ontario Canada
    Ok then, it's official. You are old. :) Go watch the news.
  3. flht99b
    flht99b Veteran Member
    351
    83
    Nov 28, 2014
    Knoxville, TN
    Me too, nearly 63 years young lol.
  4. ULTM8Z
    9,316
    455
    May 19, 2000
    Los Angeles
    Took out for another drive yesterday evening...
    I will say this, despite all the issues and headaches that popped up due to the GV install, it was still worth the hassle to have all those gears on tap... what blast it is to drive...
  5. ULTM8Z
    9,316
    455
    May 19, 2000
    Los Angeles
    Put the stock mount back on... yeah it's just so much smoother and quieter than the urethane.
    And now with the added clearance from removing the remnants of the brace in the tunnel, there's sufficient clearance that the GV doesnt hit the tunnel anymore.
    Driveability wise I'm back to where I was with the stock converter, but with the performance benefit of the GV and higher stall... finally.
  6. CorkyE
    10,531
    546
    I've been shadowing this thread. Glad you've got it pretty much worked out now. I thought about a GV unit, but I just can't justify it now.
  7. G72Zed
    G72Zed Veteran Member
    1,352
    373
    Sep 8, 2015
    Well, I'm glad you found your issue, and it's worked out in the end, although you stated in your initial post that the GV unit was not in fact hitting the floor.
    Lots of good info shared anyway that others could refer to in the future.
    And, still in my view, it's one of the reasons why GV does not go into details of the floor mods that may be needed for certain models, it would just eliminate those potential sales.
  8. ULTM8Z
    9,316
    455
    May 19, 2000
    Los Angeles
    Yeah initially I didnt realize how much the GV was able to move around back there until I got a small crowbar and moved it around by hand hand and discovered just how soft the stock trans mount really is.
    The unit is so far back of the mount that even a small movement at the mount translates into a very significant movement at the GV.
    What i should have done at the very beginning was remove every last bit of the brace in the tunnel rather than just the raised portion. It just so happens that the widest parts of the GV lines up with the spot weld flanges on that brace.
    I actually found the small witness marks on the GV from where it was hitting.
    But I'm glad that the issue flushed out the driveline angle out-of-spec and I got that back in line. Though I will say I haven't noticed any changes in the way the car drives with the angles back in spec...
  9. 80sz
    80sz Veteran Member
    3,238
    449
    Feb 2, 2014
    Buffalo,n.y.
    Glad it worked out! A in car video of car banging thru gears would be nice....
  10. jvle95
    jvle95 Veteran Member
    203
    16
    May 14, 2007
    SF Bay Area, CA
    ...and some pics of the tunnel brace removal area?
